355 - Fuel lines spaghettis! | FerrariChat
355 Fuel lines spaghettis!
Discussion in '348/355' started by radback, Oct 27, 2022.
Tags:
  1. radback
    radback Formula Junior
    730
    France
    Hi,
    I got my car back from a belt service + fuel lines change last week and tonight I had the time to have a look.
    I was not very please with what I saw:
    This is a mess!
    As you can see where red arrows are pointing: clips shoudn't be at those places, and they're missing where they should be at green arrows.
    Clip is useless there, and missing in place of this zip:
    Furthermore, some lines seems to be at wrong position:
    Line A should cross over line B, not under.
    I moved the clips at a better position (red arrows) it is better even if not perfect, that should do until lines crossing problem is fixed.
    To do this, there is only one screw to unscrew the plate that retains the lines on the divider? Correct?
    So: unscrew, remove line A, pass it over line B, put it back into divider, screw back the plate and I'm done?
    I hope I ddin't forget anything, but any advice is welcome.
  2. Tarek307
    Tarek307 Formula 3
    1,346
    Long Beach, CA & Alexandria,Egypt.
    Tarek Salah
    Certainly not something you want to leave unresolved if they are indeed not placed correctly- Fuel lines are no joke on our cars
    26street and Doug. like this.
  3. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,441
    Los Angeles
    I would like to see some original photos of fuel lines and clip arrangement on 355's as they came from the factory. Half our cars probably have the routing and clips installed wrong.
    tatry68 and MAD828 like this.
  4. radback
    730
    France
  5. Targatime
    Targatime Formula 3
    Feb 22, 2014
    1,441
    Los Angeles
    @radback Thank you, that is perfect
  6. Zamboniman308
    Zamboniman308 Formula Junior
    Feb 2, 2020
    504
    Chicago IL
    Shaking my head at the whole fuel delivery system. :rolleyes:
    Targatime likes this.
  7. radback
    730
    France
    bertrand328, Qavion and 308 GTB like this.
  8. 308 GTB
    308 GTB F1 World Champ
    11,665
    New Jersey
    Barry Wolinsky
  9. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,177
    CT
    John Kreskovsky
    Here is the doc with pictures
  10. radback
    730
    France
    So?
    Could you confirm me what I have to do to swap the lines is accurate in the above description?
  11. radback
    730
    France
  12. Carmellini
    Carmellini Formula Junior
    Jul 16, 2019
    914
    I would disconnect all the lines and start over emulating the photos posted.
  13. 26street
    26street Formula Junior
    Jan 30, 2021
    442
    Westchester New York
    Mark k
    ???? Not that I want to know who did the work but did you ask the shop to rectify that or you are going to just do it yourself
    Im a little ocd and that would drive me nuts because I would question everything they touched
    Sorry not looking to stir the pot
  14. radback
    730
    France
    Yes I asked the shop to fix it, but if I can avoid to travel there and waste my time just for that I'd rather do it myself if I can...
    There is only one line to disconnect and pass it the correct way and put it back.
    I was badly surprised by this, but the rest of the work seems fine.
    This garage has a good reputation. During the time my car was there, there was a couple of F40, an Aventador, a Testarossa and other Ferraris and Porsches.
    Not a warranty of a good work, but definitively not a bad sign :)
