430 - Fuel Map for Aftermarket Exhaust Manifold | FerrariChat
430 Fuel Map for Aftermarket Exhaust Manifold
Discussion in '360/430' started by JPCIII, Oct 18, 2024.
  1. JPCIII
    JPCIII Karting
    Oct 4, 2024
    126
    Katy, Texas
    Jason P Curtiss III
    So for those of you that replaced your crappy OEM exhaust manifold with an aftermarket header sans cat, how did you adjust your fuel map to compensate for the freer flowing exhaust?
    Jason
  2. GogglesPisano
    GogglesPisano F1 Rookie
    3,213
    East Bay, California
    Joe
    360Trev tune.
    jerbear27 and flash32 like this.
  3. JPCIII
    JPCIII Karting
    Oct 4, 2024
    126
    Katy, Texas
    Jason P Curtiss III
    Thank you; so where do you get a 360Trev tune and will it work with a 430?
    Jason
  4. GogglesPisano
    3,213
    Joe
    There are tuners Trev works with in each area. You can message @360trev to see whom he might recommend.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Why do you need to start adjusting it, I put Capristo manifolds on mine and it is a straight swap.
  6. JPCIII
    JPCIII Karting
    Oct 4, 2024
    126
    Katy, Texas
    Jason P Curtiss III
    It's my understanding that the aftermarket headers do not have a pre-cat like the OEM manifolds and, therefore, are less restrictive than the OEM manifolds. The freer flowing aftermarket exhaust systems will cause a lean fuel mixture, which may necessitate adjustments to the fueling in order to compensate.
    Jason
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    You are correct that after market exhaust do not pre cats, the exhaust O2 sensors will adjust to suit. Not heard of anyone adjusting the fuel system.
    flash32 likes this.
  8. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,945
    Central NJ
    Dominick
