Fuel Pressure regulator question | FerrariChat
Discussion in '348/355' started by treedee3d, Oct 26, 2011.
  1. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    I need 2 of these for my 95 2.7 355 and I was only able to get 1 from Rockauto at 170$ a piece. Ricambi and Ferrari have this part listed at a ridiculous price of 1000$
    Contacted Bosch Canada, Bosch USA, several websites and several parts dealers and I am unable to locate another one....this part is driving me crazy!!! If anyone has this item in stock or knows where to get it, please post!!
    Ferrari of Central New Jersey can get them at 499$ but it will take a little time.
    I sometimes see "universal adjustable fuel pressure regulators" online but was wondering if anyone ever used these?
  2. gus355
    gus355 Formula Junior
    Aug 3, 2011
    569
    B.C. and WA
    OK, 2 ideas -
    How about a used one? Maybe ferrparts or someone?
    What is actually wrong with yours? Maybe you can rebuild them?
  3. bcwawright
    bcwawright F1 Veteran
    Jul 8, 2006
    5,234
    Georgia
    Bruce
    I have a used one in perfect condition...it is the factory original $1000 one and not the aftermarket version that is sold by Rockauto.
    These units cannot be rebuilt.
  4. Philip Barnard-Browwn
    Feb 25, 2007
    168
    london.
    Philip Barnard-Brown
    Bosch part 0280 160 731
    Same part used on Volvo 960 or S90
    Also used on Alfa and Renault.
    Please chck 348 parts interchange sticky.
    Good luck.
  5. gus355
    Aug 3, 2011
    569
    B.C. and WA
    I still wonder what went wrong inside of it? Is it the diaphragm that is ruptured?
  6. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    That's exactly what my mechanic said, the diaphragm is ruptured. I will try looking and understanding what he's talking about.
    For the ones who have responded with the Bosch number, thank you....However, it is the wrong part number. The 355 uses Bosch #0 280 160 564 and it is different than the Bosch #0 280 160 731 for the 348
  7. vvassallo
    vvassallo F1 Veteran
    Aug 4, 2006
    8,328
    Palos Verdes
    Vince V
    You should still be able to find an equivalent part for another vehicle. These things are never Ferrari-specific. Can you get the specs on the part? What psi or bar does it have and what are the connector sizes? I am sure you can come up with a more affordable replacement than stock.
  8. gus355
    Aug 3, 2011
    569
    B.C. and WA
    If the diaphragm is ruptured, you could try swapping it - the reg. body looks the same as almost every other Bosch reg out there. This would involve uncrimping the canister and changing the diaphragm, not easy, but I have done it in the past.
  9. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    #10 treedee3d, Oct 29, 2011
    Ended up finding another one of these from t.rutlands at 429$ still insanely overpriced for such a small simple part and much more expensive than the 180$ rockauto charged me. However, cheaper than spending 1000$ from ferrari
  10. gus355
    Aug 3, 2011
    569
    B.C. and WA
    Did rockauto not have an ETA on the part?
  11. F355Bob
    F355Bob Formula 3
    What happens when one of these regulators goes bad? Does the car run poorly or is it just hard to start?
  12. gus355
    Aug 3, 2011
    569
    B.C. and WA
    Sorry I was late to see you posted this - YES - you could have easily gotten a pair of adjustable regulators from aeromotive or AEM or SX - they may even have them with the correct spacing or have an adapter to bolt them up.
  13. gus355
    Aug 3, 2011
    569
    B.C. and WA
    I would think that if the diaphragm is ruptured it may cause fuel to shoot up the vacuum lines - I have seem this on a car before.
  14. tamf328
    tamf328 Formula Junior
    Mar 9, 2005
    477
    on my previous 348 when the regulator failed there was raw fuel in the vacuum lines,
    which on most occasions would dump raw fuel into the plenum and it was bear to get the thing started when hot (flooding comes to mind).
    the other unique thing that it fixed when I replaced them was the sometimes annoying stumble at idle when extra fuel would make its way in to the intake....
    the vacuum lines on the 348 are connected to the plenum as I can remember.
    yeah that cleared up a few issues with that car....
    along with a bunch of other things
    you can check if they are leaking by pulling off the vacuum line after you run the car awhile.
    on the 348 I got the regulators from bosche
  15. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Fab if you see this what was the symptoms
    Bad starting/?
    You never did tell us.
    Peter likes this.
  16. PaulK
    PaulK F1 Rookie
    4,783
    Michigan
    Paul
    Qavion likes this.
  17. treedee3d
    treedee3d F1 Rookie
    Apr 1, 2011
    3,726
    Montreal
    Fab
    Honestly this happened a decade ago when I first purchased my 355. I knew nothing about it and the shop that was doing the major basically said I “needed” new ones so I got them but never actually bothered to learn why….
  18. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Dam that doesn’t help
    Thanks anyway
    treedee3d likes this.
  19. POLO35
    POLO35 Formula Junior
    Feb 21, 2005
    783
    Treasure Coast Florida
    MATT
    Just thought I would chime in. I just recently replaced my fuel pressure regulators on my 348 which actually has 2. One side was leaking so bad that was flooding the engine and almost impossible to start hot, plus I could smell raw fuel after shut down. I thought for sure I needed the dreaded repacking of the clutch but all along it was the fuel pressure regulator. Anyway these are very very hard to come by now.... Ferrari wants $960 you can find them around $500 to $600 on eBay. Even then you might be buying a 30 year old part that is new old stock. Anyway, after many many many hours of searching, research and ordering parts and checking the fitting sizes, I was able to source an FPR from Brazil at a reasonable price and I'm selling them on eBay. These are an exact replica of the original bosch and a drop in replacement with 3.8 bar pressure. But again this is for the 348 1992 on. What I learned in my searches is these regulators have a metric inverted flare fitting which is unique for fuel. Moreover there are companies that sell adapters, for example that can change a fitting from say, 14 mm to 16 mm so forth and so on. I've got a lot of time on my hands so I'm going to try to source one for the 355 and will report back if I have any luck.
    Julia and Qavion like this.
  20. POLO35
    Feb 21, 2005
    783
    MATT
    Does anybody have any specs on this fuel pressure regulator for the 355?? Specifically how many bar and the thread size it looks to be 14 x1.5 mm or possibly 16x1.5mm reverse flare.
  21. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    That year 348 uses 3.4 bar not 3.8 btw.
    Sent using FerrariChat.com mobile app
  22. POLO35
    Feb 21, 2005
    783
    MATT
    That's interesting to know. What I found was 1990-1992 348 use a barbed FPR which was actually 3.0 bar. Then mid production from 92 to 95 switched to a nonbarbed 3.8 bar. I can't magine that would be of significance but it's good to know. I'm still trying to find out the exact specs of the 355 fpr. At this point I believe it to be 3.5bar which is 50psi
  23. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Plenty of 348 FPR threads as well as 355 FPR threads. I would be you can order standard Products FPR for 355 from Rock auto. Isn't the 355 original FRP marked for 3.9 bar?
  24. m.stojanovic
    m.stojanovic F1 Rookie
    3,234
    Serbia - Niš
    Miroljub Stojanovic
