348 - Fuel pressure | FerrariChat
348 Fuel pressure
Discussion in '348/355' started by marc556, Jul 25, 2020.
  1. marc556
    marc556 Formula Junior
    590
    Wiltz (Lux)
    Marc Foyen
    What it the fuel pressure on a F119D040 engine (ECU 2.5) ?
    I can not find the info...
  2. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Qavion likes this.
  3. m.stojanovic
    m.stojanovic F1 Rookie
    3,177
    Serbia - Niš
    Miroljub Stojanovic
    I included the info (from the manual) on the fuel pressure in your "Difficult to start when the engine is hot" thread.
  4. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Yes, I saw that of course, but i'm really desapointed, i spent hours on the phone with Ferrari friends from neighbour countries and it became absolutly not clear.
    I I ordered 2 FPR NAPA PR161, there work at 3.0 bar (if i remember well), I just hope that the threads are the same as original.
    I want to be sure that I received the right parts before I work on the car, because it is not so easy to do the job and i don't want to do it 2 times.
  5. m.stojanovic
    3,177
    Serbia - Niš
    Miroljub Stojanovic
    I bought two FPRs for spare, Bosch 0 280 160 731 which is for Volvo 960 (B6304F), S90 and V90 (Volvo p/n 1306965, 3547653). It seems that PR161 is equivalent to Bosch 0 280 160 731 since it is also for Volvo and it looks identical. I have not tried to install my Volvo FPRs but it looks like some mods will be required, on the return line connection at least. Let us know how it goes when you receive the RP161-s. Picture of Bosch 0 280 160 731:
    ernie likes this.
  6. marc556
    590
    Wiltz (Lux)
    Marc Foyen
  7. m.stojanovic
    3,177
    Serbia - Niš
    Miroljub Stojanovic
    Here's what the Bosch catalogue states for Bosch FPR 0 280 160 731 (which looks identical to PR161): 348 F119 V8 3.4L, November 1990 on. The catalogue also specifies this FPR for Volvo 960, 09.91 - 07.98, engine B 6304 FS.
    For 348 F119 V8 3.4L up to October 1990, the catalogue specifies Bosch 0 280 160 715. This FPR is also specified for Mondial, F119D, up to October 1990.
  8. 308 GTB
    308 GTB F1 World Champ
    11,666
    New Jersey
    Barry Wolinsky
  9. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    #10 Ferrarium, Jul 27, 2020
    That is interesting, I did not see it state the difference in pressure between 0 280 160 731 and 0 280 160 715 in the catalog only xref numbers. One xrefs to Ferrari the other to Volvo. I assume its the same 3 bar and was an availability thing as all my checking shows 3.0 bar for both. The volvo version does not have a barb for the hose.
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  11. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Very interesting....
  12. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,423
    San Carlos, CA
    Mitchell Le
    So did we figure out if there is another FPR that fits the 348?
  13. m.stojanovic
    3,177
    Serbia - Niš
    Miroljub Stojanovic
    I think we need to clarify which 348s use 3.0 Bar FPRs and which (if any) use 3.8 Bar. I still do not have clear info about this and hope that someone can solve the puzzle. Daniel from Ricambi also invited. This is what I found so far:
    1. Ricambi show that both, 3.0 and 3.8 Bar FPRs, p/n 137960 & 147281 respectively, are for 348 89-92 & Mondial T
    2. The 3.8 Bar FPR is Bosch 0 280 160 738 (info and picture provided to me by Marc Foyen, thanks)
    3. The Bosch catalogue specifies 0 280 160 738 (3.8 Bar) for Mondial T only, November 1990 on
    4. The Bosch cataloge specifies 0 280 160 731 (3.0 Bar) for 348, November 1990 on
    5. The Bosch catalogue specifies 0 280 160 715 (?.? Bar) for 348 and Mondial T up to October 1990
    My 1991 2.7 348 has 3.0 Bar factory FPRs (in situ, I can see the "3.0 Bar" on the FPR but cannot see the Bosch number) which is consistent with the info in the Bosch catalogue so my FPRs should be 0 280 160 731 (which is also used in Volvo 960)
    So, the question is: did any 348s had 3.8 Bar FPRs and, if yes, which 348s (Bosch catalogue states that only Mondial T used 3.8 Bar). According to the info I have, the 2.7 348 came with 3 different ECUs:
    0 261 200 457 = M27 Ferrari 348 TS/TB, Ferrari Part 142519, FPR 147281 - 3.8 bar according to Ricambi but my 91 348 with "457" ECUs has 3.0 Bar FPRs
    0 261 200 489 = M27 Ferrari 348 Spider & Chall. Ferrari Part 147176 (supers. by 156536), FPR ???
    0 261 203 327 = M27 Ferrari 348 - Ferrari Part 156536 (supers. from 147176), FPR 147281
    If any 348s had 3.8 Bar FPRs, did they only come with certain ECUs? Or were 3.8 Bar FPRs used only in 2.5 348s (ECU 0 261 200 190)?
  14. m.stojanovic
    3,177
    Serbia - Niš
    Miroljub Stojanovic
    If your FPRs are 3.0 Bar and push-on (barb) connection for the return hose, then it is Bosch 0 280 160 731 used in Volvo 960. The Bosch catalogue actually specifies the 0 280 160 731 for Volvo 960 and for 348 from November 1990 on.
  15. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    the 3.8 bar was used sometime in 92 and with the spider starting at engine 27843. The difference was ECU map and Exhaust and they increased fuel flow through pressure as opposed to larger injectors.
    Everything prior was 3.0 bar.
  16. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Which is the Standard Motor Products PR161 xref fore the barb 3.0 car version.
    BTW my car was October 90 and it had the 715 on it. They are all the same 3 bar (715 & 731) and it was an availability thing prompting the November change I suspect as even used the 715 are almost impossible to find.
  17. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    thank you guys, you gave a lot of information on a completely unclear point !
  18. m.stojanovic
    3,177
    Serbia - Niš
    Miroljub Stojanovic
    So, in summary, the 348 FPRs should be:
    Up to 1992 - 3.0 Bar, Bosch 0 280 160 715 (nla) or Bosch 0 280 160 731 (easily available, Volvo 960, also S90 & V90, p/n 1306965, 3547653), Ferrari 137960
    1992 and later - 3.8 Bar (possibly not on all models, perhaps Spider & Challenge only), Bosch 0 280 160 738, Ferrari 147281
    In any case, the best is to read the Bosch number on the old FPR.
  19. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  20. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Thank you so much for all your comments guys !
    nice help!
  21. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    Mine is 0 280 160 715
  22. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Yes mine was 0 280 160 715 also being a 90 my. I replaced with PR161. The Bosch are in a box. Good luck.
  23. marc556
    590
    Wiltz (Lux)
    Marc Foyen
    The FPR are replaced, it was very easy...
    PR161 are exactly the same as original no modification is needed.
    When I disconnected the fuel line from FPR to injectors pipe, I had some fuel drops that fell out of the pipe (on the left right side), but really more fuel fell out on the left side.
    So I installed the FPRs and I switched ON the ignition 30sec until the pumps stop and then I started the engine to do an ECU reset.
    The engine ran very nice.
    When fan started, I switched OFF.
    I waited 3 or 4 minutes and it restarted perfectly.
    Tomorrow, I shall use the car for a trip of 50 km, to check if the hot start is ok.
    I keep you informed !
  24. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The fuel pumps are not powered until the car starts, switching the ignition does not prime them. I stuck a volt meter there to check when I replaced my fuel pumps.
    Qavion likes this.
