Fuel proof sealant | Page 2 | FerrariChat
Fuel proof sealant
Discussion in 'Technical Q&A' started by wildegroot, Dec 11, 2006.
  1. bretm
    bretm F1 Rookie
    Feb 1, 2001
    4,577
    Northern NJ
    Bret
    fwiw, I JB welded the intake manifold of my Jeep ~3 years ago and it's still good as new. Hasn't broken down or distorted at all from being exposed to fuel. It's a carbed, 4.2L L6.
    I had a rebuilt engine put in a few years ago and the mechanic must have overtightened one of the bolts holding the runners on. So, a month or so later a quarter size piece broke off right where the manifold meets the head. JB weld, some file and sandpaper work, and it's sealed fine ever since. It's 3/4" from the header... you'd think with all the heat cycling, especially in the cold of winter, that it would break down but I had it off a month ago when I spun a rod bearing and it really is good as the day I put it on. Go figure.
  2. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
    Thank you. I considered JB-Weld. It's a great product for many purposes but the fine print says water PROOF and fuel RESISTANT. Not good enough and too difficult to remove if I need to disassemble. I ordered two different types of sealant this morning on other F-chatters' advice and I'm going to experiment with those 2. I may use both since one is an assembly paste and the other is a type of caulk that can be scrapped away for disassembly. Both should be fuel proof.
    I'll post my results!
