355 - Fuel pump and regulator symptoms | FerrariChat
355 Fuel pump and regulator symptoms
Discussion in '348/355' started by taz355, Oct 12, 2021.
  1. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Reaching out to the brotherhood on people who have had either issues.
    If you have could you please describe what happened on your car for symptoms.
    some posts did not always have the symptoms but rather how to replace.
    thanks
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,574
    San Carlos, CA
    Mitchell Le
    Grant, why are you asking? What gives?
  3. PaulK
    PaulK F1 Rookie
    4,782
    Michigan
    Paul
    Well I haven't tackled it yet but if the car sits for a while it is hard to start. I suspect it has to do with the fuel pressure regulators being 26 years old. When I finish my engine stand I am going to go through the entire fuel system and replace all the hoses, rebuild the pumps, and tackle that issue.
  4. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    Its old oct 12
    Working through the stuff we talked about
    Also trying to help data base on here before discussing with you could not find pressure regulator
    Symptoms but in other thread not this one
    Still need too switch d/s coil
  5. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    I just noticed your post was old as well oops
  6. 26street
    26street Formula Junior
    Jan 30, 2021
    469
    Westchester New York
    Mark k
    Some symptoms will be if the regulator diaphragm fails and let’s fuel into the vacuum hose
    1) running rich at idle
    2) flooding (no start)
    3) fowling spark plugs (wet with fuel)
    4) smelling fuel in the intake after the engine is off
    This are a few thing there is more but these are easy to check
    Next if the valve sticks closed
    1) loss of performance in mid to high range driving
    2) codes for running lean
    3) over heating when driving hard (most on hot days)
    4) engine knock (predestination do to high cylinder temperatures)
    Again just a few
    And if the valve is stuck open
    1) loss of performance at idle, low rpm and speed (lack of response and sluggishness)
    2) fowling plugs if idling for long periods of time
    3) codes for running rich
    4) clogging CATS if idling for long periods of time and low rpm and speed
    This are just a few there is more
    If you have access to scan tool just look at short and long term fuel trims
    Short should be close to 0 as possible +4 -4 is ok this is how the ecm corrects fuel after reading o2 sensors
    long term numbers are what the ecm is going to off set the fuel term so that the short term doesn’t have to work as hard and keep the term in lower numbers (aka range) if u have low counts in both long and short this means that the ecm is taking fuel away because of running rich which can be from regulator
    Again there is more but too much to type lol
