360 - Fuel pump cross reference part numbers | FerrariChat
360 Fuel pump cross reference part numbers
Discussion in '360/430' started by wheelman76, Jan 20, 2022.
Tags:
  1. wheelman76
    wheelman76 Formula 3
    Feb 22, 2004
    1,125
    Midwest
    Was doing some shopping for new pumps to get done this spring on my car as I have no record of them ever being done and so far see that Eurospares having an attractive price but upon looking further I found one of them on ebay and it notes the pumps as Bosch at a considerably lower cost. After finding the first pump I couldn't find the opposite side anywhere and I am wondering if anyone is familiar with cross referencing the Bosch numbers for these pumps or of they've ever done it? Or am I not seeing what I think I'm seeing?
  2. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I have that info I can provide when I get back.
    It can be very confusing
    Be careful with eBay listings
    I bought upgraded 430 fuel pumps for my 360 from Eurospares.
    I also bought new fuel lines as those age as well
    I will give you that info from Eurospares
  3. timwu12
    timwu12 Formula Junior
    Oct 31, 2014
    918
    TX
    I’d like that info as well!
  4. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    I will be back next week and will post that info
  5. MiBe
    MiBe Rookie
    Jun 7, 2021
    33
    Sweden
    Mikael Berg
    I think the Bosch numbers are:
    0580313088 RH fuel pump
    0580314061 LH fuel pump incl fuel level float indicator.
  6. wheelman76
    Feb 22, 2004
    1,125
    Midwest
    I that for a 360? The ebay listing that I was corresponding with only had one of the two on hand and then gave me the bosch number of the one they didn't and they said it was 0 580 314 060
    This is the one they carried and offered on their ebay store. https://www.partsinmotion.co.uk//car-parts/ecu/fuel-supply/boschfuelpump0580313051-detail
    It appears neither of your parts match up to what I found... Last thing I want to do is get the wrong pumps. It's not the end of the world to get from Eurospares, but it's a couple hundred saved if I can find the right numbers and get bosch brand.
  7. Sj_engr
    Sj_engr Formula 3
    Sep 15, 2020
    1,583
    San Jose
    dc
    I can 2nd good results from Eurospares. Ordered pump came super fast and you can use a water filter wrench as part of the install.
    Does the 360 have the extra tank top bolts to allow the easy insert of the pump or do you have to drop the tank?
  8. MiBe
    MiBe Rookie
    Jun 7, 2021
    33
    Sweden
    Mikael Berg
    Ok sorry I forgot to mentioned that these numbers are for the Spider. Modena have different numbers.
  9. GCalo
    GCalo F1 Veteran
    Sep 15, 2004
    7,645
    Northern California
    Greg Calo
    "does the 360 have the extra tank top bolts to allow the easy insert of the pump or do you have to drop the tank?"
    tanks do not need to be dropped
    coupes are somewhat easy to replace the pumps.
    Early spiders do not have tank access and whole top mechanism has to come off
    Later spiders have access doors to get to the pumps but not easy access to rollover valves
