Fuel pump keeps ticking...! | FerrariChat
Discussion in 'Technical Q&A' started by rmdferrari, Mar 18, 2005.
  1. rmdferrari
    rmdferrari Formula 3
    Jan 6, 2005
    1,383
    Gatwick, UK
    Richard
    When the ignition light is on, the fuel pump on my 308 GT4 keeps ticking away with no sign of stopping. Whilst tunning in the radio it was "ticking" for 5 minuites or so. Is the right? I've experience of other old cars that tick for say, 20 seconds then once the chamber is full they stop. Any ideas?
  2. Steve Magnusson
    25,144
    Richard -- Your 308GT4 has a "continuously recirculating" fuel system (i.e., there's an intentional small leakage path from the supply fitting on the 7/8 carb into the RH side fuel tank) so the pump never completely shuts off.
  3. Peter
    Peter F1 Veteran
    6,432
    B.C., Canada
    If the car has it's original Corona BCD pump, it should run with a faint humming/buzzing sound. Does it have another type of pump in there (Facet or SU)? These typically have a very mechanical sound (especially the Facet, they make terrible noises!).
    As Steve says, there's an over-flow fitting on the right-hand, front side carburetor and when I start my car up for the first time, I wait to hear that fuel splashing out of that hose into the tank, then I know the bowls are full and I can then start the car.
  4. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Just so it may make some more sense, an advantage of the constant loop fuel system is that it provides a constant availability of cool fuel and helps to avoid vapor lock.
    best
  5. Ken
    Ken F1 World Champ
    Oct 19, 2001
    16,078
    Arlington Heights IL
    Kenneth
    A loudly ticking fuel pump frequently means you have blockage in the fuel line or you need to change the fuel filter. Unless GT4 pumps always do that...
    Ken
