fuel pump plastic crack? | FerrariChat
Discussion in '360/430' started by 24000rpm, Aug 18, 2013.
  1. 24000rpm
    24000rpm F1 Rookie
    #1 24000rpm, Aug 18, 2013
    car is throwing p0455 and p0442 and a huge fuel smell, so I check the fuel system and see what's the problem.
    simple question: for a 360 modena, is it possible to have a crack on fuel pump's top plastic parts that's not visible to the naked eye?
    I observed a lot of liquid gas in the grid shown in the attached picture but I can't find any cracks on the plastics.
    do I need a new pump in this case?
  2. vrsurgeon
    vrsurgeon F1 World Champ
    16,527
    Charleston, SC
    Curt
    Mine did same thing. Crack not visible to eye, drip drip drip of fuel that pools on the top of the pump creating a fire hazard.
    Replace it.
    Worst case scenario possible is you let it go too long and the plastic nipple at the outflow to the engine cracks visible to the eye. All the high pressure fuel sprays into the compartment, catching fire and ***POOF***.
  3. 24000rpm
    24000rpm F1 Rookie
    what code were you having? do you still remember?
  4. TheMayor
    106,121
    Vegas baby
    I just replaced the 2 Fuel pumps on my Maserati for the exact same reason. Looks identical to this photo. Seems like the plastic on these things last about 10-15 years and then cracks.
    Yes, you need a new pump. It cannot be fixed. Driving with a leak is a huge fire risk.
  5. vrsurgeon
    16,527
    Charleston, SC
    Curt
    Mine had no codes! It's a euro 1999. I'm proactive with my cars and noticed that the garage was a bit too "fuel smell" after a drive. So I did the sniff test (sniff the holes in the engine compartment trim panels) and noticed a gasoline smell when there should be none. So I opened it and noticed fuel in the valley on the pump. Replaced.
    I predict the reason you got the codes, was the crack let the pressure out of the system and the switch on the tank detected it. Similar to leaving the gas cap too loose giving you an error code relating to evaporative emissions.
    I love my 1999, sooo much simpler car without the emissions crap.
  6. mr_bock
    mr_bock Formula 3
    Oct 27, 2006
    1,373
    FL full time
    I don't remember the codes, but the Indy Shop pressurized the fuel system with nitrogen that revealed vapor leaks from three of the four hoses/plastic fittings from the top of the two tanks (roll over shut off lines). Each hose cost $250 USD.
    The more I get into my 360, the more I see less than stellar parts/product/design quality.
    This is my first and last Ferrari I will own. These cars are fragile at best!!!
  7. TheMayor
    106,121
    Vegas baby
    It's Bosch. Blame the Germans. :)
  8. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,596
    Gates Mills, Ohio
    Jon
    Did the 997s have this problem?
    Maybe Ferrari gets the Bosch cast-offs.
  9. TheMayor
    106,121
    Vegas baby
    #9 TheMayor, Aug 18, 2013
    Honestly, you can't complain about a fuel pump going bad over 14 years. Your average Chevy or Camry is crushed in 7.
    I think this shows that garage queens don't mean that the cars are as good as they were when you put them in storage. Father time attacks plastic, rubber, leather, aluminum, and anything that can be oxidized or chemically damaged.
    My boss has a 60's vintage era Mercedes convertible. He drives it once a year. Last week he went out and found a river of gas running underneath it. Fuel line just got eaten up -- probably from Ethanol in the fuel these days.
  10. vrsurgeon
    16,527
    Charleston, SC
    Curt
    Interestingly my 986 had a similar pump with no issues. I suspect the warmer operating conditions accelerate the breakdown in the 360 vs Volvos and Porsches. Different designs and component stresses on the plastic. 997 has pump under the front hood in. Much cooler environment.
  11. 24000rpm
    24000rpm F1 Rookie
    i searched and saw your post about sniff test before I posted mine
    it seems that the liquid fuel you were having was on a different location (side)
    where I was having, is on the top , the "X" shape grid area
  12. tazandjan
    39,166
