Fuel pump problems...help please | FerrariChat
Discussion in '348/355' started by A348W, Nov 8, 2017.
  1. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    Hey after some advise please...
    So the engine has done the odd cough recently, and the other day, one bank completely died.
    After getting home running on one bank and being p***ed off, I read a few forums etc and did some diagnostics, its the what next bit I could do with some help with.
    I checked:
    - all the fuses and relays, they are all ok;
    - I disconnected both exhaust ECUs and the car still ran on one bank only;
    - I then swapped the ECUs and the car still runs on the same bank, so they are fine;
    - I then disconnected the fuel line at the fuel filter for the bank not working, whilst the engine was running, and nothing came out at all.
    Clearly a fuel problem. My initial thought was fuel pump; but reading some threads it appears that the crank sensors tell the fuel pumps when to kick in?
    I will check that the pumps get voltage when the ignition key is turned on (tomorrow evenings job).
    I would have through that as soon as the ignition key is turned on, the pumps should prime irrespective of the crank sensors. Hence if I listen/feel at the fuel pump and get somebody to turn the ignition key I should be able to detect if the pump is priming. Is this reasonable logic?
    Also if I do need to replace a fuel pump, are the pumps actually in the tank and I have to drain the tank, which seems to be the case and just plain stupid!
    Appreciated
    Adrian
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    Which model?
  3. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    dooh! 348TS 1992
  4. yelcab
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    I got to look it up before I can tell you if the pump is running when the key is on without ignition. I don't think so because of safety reasons.
    you can test the fuel pump by itself by crawling underneath, disconnecting the wires, and apply 12V to the pump. It should whir.
    If it is bad and needs replacement, you have to drain the tank. Stupid? This is an Italian car, stupid is a feature.
  5. Qavion
    Qavion F1 World Champ
    14,271
    Ian Riddell
    Putting fuel pumps in tanks is considered a safety feature (especially on aircraft), in theory at least. It keeps the pumps cool being immersed in fuel, and if the pumps leak, the fuel just goes back into the tank. On aircraft, however, the pumps can usually be removed without draining too much fuel.
  6. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    SoCal LA/OC/New Mexico
    Tim Dee
    Crank sensors need to see 30 rpm to turn fuel pumps on
    Simply hot wore the pimps to see if they work
  7. Nader
    Nader Formula Junior
    Feb 12, 2011
    990
    East of Seattle
    I read that as "simply hot-whore the pimps to see if they work," which would have qualified it as the greatest sentence written of all time.
  8. yelcab
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    How do you hot wire the pimp? Does it take a couple of employees?
    taz355 and SoCal1 like this.
  9. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
    I know what Santa is bringing you kiddies for Christmas LOL
  10. taz355
    taz355 F1 Veteran
    Feb 18, 2008
    6,016
    Indio Ca/ Alberta
    Grant
    You put two wires in the stove burners for a while and then invite the pimp over!,
  11. m.stojanovic
    m.stojanovic F1 Rookie
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    The fuel pumps do not run with the ignition "on", they will start running when the engine is cranked based on the signal from the crank sensors. The first thing to check is the fuel pump relay (see attached pic). Pull it out and clean its pins, check if it works and check the socket for any melting signs. If the pump still does not work, check fuses 8 or 19 depending on what side pump does not work (the fuse might not be blown but its pins might be corroded/burnt). You can test the pump by inserting two male spade connectors in the pump relay socket where the relay pins 30 and 87 go (see 2nd pic) and jumping the connectors with a piece of wire. You do not need to switch the ignition on for this test.
    Qavion likes this.
  12. tr0768
    tr0768 Formula Junior
    Oct 28, 2008
    736
    Lake Stevens Washington
    Howard Musolf
    Starting a major service on my 348 spider. Daniel from Racambi let me know with the ethanol fuel today, it attacks the rubber boots around the fuel pump. This sluffing off of chunks of rubber will stop the fuel pump from pumping fuel and the rubber chunks drop to the bottom of the tank and clog the pick ups. Not sure if your earlier car mine is a 94, has these offending boots. While the service is being conducted I am removing the pumps and rebooting. I am also sending the tank out to be steam cleaned. I'm a belt and suspenders kinda guy and doing everything possible now to make my touring season trouble free. I'm replacing every part that moves, rubs, applies pressure, all bearings, seals and wear items in the timing case, including Daniels new improved water pump. It is more expensive to do "everything" that moves replacement but in the long run peace of mind is worth it.
    I would check the flow of fuel from the pump, check the ohm draw on the pump leads and the old stand by put your ear to it and listen for noise. As a rule things jut don't stop working with out prior notification of some sort. Basic diagnosis is your inexpensive friend in this case. I believe new pumps are north of a couple of grand. The new boots are $130 each.
    just sayin'
    brasscarguy
  13. m.stojanovic
    3,222
    Serbia - Niš
    Miroljub Stojanovic
    Qavion, Nader and SoCal1 like this.
  14. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    Ok, thanks for the replies so far!
    I hot wire the fuel pump this morning as per above and it ran no problems.
    I also ran the car and hot wired the pump, but it still only ran on one bank. I'm guessing/hoping that the crank sensor not only tells the ECU when to fire up the pump, but also when to start the ignition as well?
    I'll order a new sensor and see what happens.
    Does anybody know what sensor runs what bank? I could disconnect each intron and see what happens, but....
    Appreciate your help so far.
    PS Not sure how we got onto pimps, but somebody is not giving FChat there full attention;)
  15. Ferrarimondial348
    Ferrarimondial348 Formula Junior
    Nov 29, 2012
    531
    Scottsdale, AZ
    Stephen
    “If it is bad and needs replacement, you have to drain the tank. Stupid? This is an Italian car, stupid is a feature”
    Funniest quote I’ve every heard on this forum.......
  16. SoCal1
    SoCal1 F1 Veteran
    Jun 14, 2011
    8,630
    Tim Dee
  17. plugzit
    plugzit F1 Veteran
    7,776
    Redondo Beach, CA
    Bruce Bogart
    You'd best just plan on replacing both crank sensors. $25/ea Kia sensors. Plugs andespecially wire insulation deteriorate over time.
    vvassallo likes this.
  18. tr0768
    Oct 28, 2008
    736
    Howard Musolf
    I don't think the fuel pumps for the later 348's use the cheap Bosch pumps. The ones in my spider is quite different from the Bosch 44's.
    just sayin'
    brasscargy
  19. fatbillybob
    Aug 10, 2002
    28,982
    socal
    #19 fatbillybob, Nov 9, 2017
    Yes use the kia sensors. They last forever and much better than Ferrari at a fraction the price.
    Kia sensors are like the 1st 348 hack ever done.
    https://www.ferrarichat.com/forum/posts/138368426/
  20. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    Ok, refitted new crank sensor.
    Started the car and it still ran on only one bank. Turned it off and looked at the crank sensors and checked the connections again, and then it ran fine...for about 5 minutes then went back to one bank.
    Any suggestions? Do I need to reset the ECUs or anything?
    Cheers
    Adrian
  21. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Any CEL or SD lights on when the bank doesn't run?
  22. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    nope, no warnings lights. l turned everything off and left it for a couple of hours ands till runs on one bank.
    Guess I'll swap crank sensors over. That should tell me if the new sensor is faulty or if there is a fault somewhere else!
  23. johnk...
    Jun 11, 2004
    11,219
    CT
    John Kreskovsky
    Well, I'm not familiar with the 92 348 and how the warning lights work compared to a 355, but once thing you might want to do is check continuity of the harness between the ECU and the C-sensor. Check each of the wires separately. I had a similar problem with my 355 this summer. Sometimes it would run fine. Sometimes it would break up badly. Then it just quit on one bank. Replaced the C-sensor and it ran fine for a while. Then lost the same bank again. Turned out to be an internally broken wire that would intermittently make contact. The wire broke inside the insulation right at the point where it was crimped to the pin in the connector at the sensor end. I had to pull the pins out of the connector housing and pull slightly on each wire. Sure enough, for one wire the insulation just stretched. Wire broken inside.
    Pangea likes this.
  24. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    As John said above. Time to check the loom.
  25. A348W
    A348W Formula 3
    Jun 28, 2017
    1,846
    North Wiltshire, UK
    actually the go slow light flashed for a second then went out as I was running it again. Though it might need some time to prime the fuel system, ran it for 5 minutes but still nothing.
    I'm also thinking dodgy wire. Anybody know what pins the crank sensor goes to on the ECU connector?
