Fuel Pump to Accumulator Connector Leak | FerrariChat
Discussion in '308/328' started by rwbolt1, May 21, 2025.
  1. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    215
    Boerne, TX
    Rodney Bolt
    I recently replaced my fuel pump and am having a hell of a time with a leak at the banjo fitting between the pump and accumulator. All new crush washers. As a matter of fact, I've tried multiple crush washers: copper and aluminum. I can see the leak is at the washers on either side of the banjo fitting and not the fitting itself, so I know it's not damaged. The leak only occurs when under pressure.
    I'm considering ditching the wonky OEM connector and Bosch check valve and replacing with AN fittings an external inline check valve. Any advice is appreciated.
  2. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,563
    San Carlos, CA
    Mitchell Le
    Check the banjo bolt for cracks.
    Steve Magnusson likes this.
  3. Steve Magnusson
    26,795
    Just a side question -- is that some non-Bosch fuel pump with some sort of adapter fitting between the check valve and the fuel pump?
    Gasoline is very non-viscous so migrates so easily that I'd still suspect every joint in the area (even the brazed tube into the banjo fitting). The joint between the thin hex of the check valve and that adapter fitting seems to have a copper washer in it but looks a little strange...
  4. Steve Magnusson
    26,795
    I just don't like having that extra fitting and joint between the fuel pump and check valve, and think maybe someone might have used the wrong check valve. This picture shows the silver Bosch 1587010536 check valve on the left used on some MB and the goldish Bosch 1587010532 check valve used on the F fuel pumps on the right. They use the same banjo fitting and cap nut, but have different sized threads to screw into the fuel pump:
    Just a thought...
  5. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    215
    Boerne, TX
    Rodney Bolt
    Good eye. Yes, it's an Evil Energy fuel pump with an adapter for the Bosch check valve. There are certainly a lot of potential failure points with so many washers. However, that adapter connection is not leaking. The leak is at the banjo washers. I can see fuel coming through between the washers and banjo fitting.
    As was pointed out, the banjo fitting might have micro cracks.
    I'm thinking of disassembling and polishing the two flat faces of the banjo fitting. Any potential issues doing that?
  6. Steve Magnusson
    26,795
    No, that would be fine (keeping things parallel). You could also go to a 2mm thick copper washer as the extra thickness gives more deformability to seal up imperfections (and make sure you always use new, soft copper washers -- or you can anneal the old ones in a pinch, but that's sort of a hassle for such an inexpensive washer).
    rwbolt1 likes this.
  7. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    215
    Boerne, TX
    Rodney Bolt
    Ahhh... 2mm copper crush washers. The copper washers I'm using are 1.5mm. That extra 33% thickness could be the key detail I was overlooking. Thanks much!
    Off to NAPA for washers. I'll post my progress.
    Sergio Tavares likes this.
  8. Rifledriver
    37,099
    Very common. Even the factory had that problem when the cars were new. Due to the design of the fitting at the pump its difficult to counterhold. the pump to tighten them. Often some rotational stress is created and in use it relaxes slightly, enough to cause a leak. I tighten all fittings with both pump and accumulator mounting clamps loose so they rotate freely and tighten them last.
    Sergio Tavares and rwbolt1 like this.
  9. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    100% agree on this, it's super important to do it that way. The pipe connects to the centerline of the fuel pump, but off-center on the accumulator. For a given spacing between the pump and accumulator, here are two "equilibrium" rotational positions the accumulator can be in (+/- up/down angle) to avoid putting stress on the pipe or connections. When I assembled my new fuel pump and accumulator on the mounting sled, I left the mounting clamps loose and gently snugged up the pipe fittings to get the pump and accumulator in whatever relative positions they needed to be in before tightening the fittings all the way. Then tighten up the mounting clamps. There is a small amount of slop where the mounting clamps attach to the sled, which will accommodate the final arrangement of the pump, accumulator, and fuel pipe.
    rwbolt1 likes this.
  10. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    215
    Boerne, TX
    Rodney Bolt
    Interesting you and Brian both recommend this technique. I've been doing the EXACT opposite; locking down the pump and accumulator down in their carriages, then tightening down the connection "hose". And the results show: Dang leaks. Ugh...
    Any recommendation on torque specs?
  11. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    It's very likely that the banjo fitting is not seating well because it started out cockeyed. The shape and design of the rigid pipe doesn't help here. It's very optimistic to think that mounting alignment of the accumulator and pump on the sled (when you lock down those clamps) is going to match whatever the pipe wants to do at both fittings. I suspect you are crushing the sealing washers down before properly aligning/seating the banjo surfaces.
    So yeah, I would be highly suspicious that your procedure introduced a misalignment. It may even be possible to notice this if you undo the clamp on one of the components and see if the pipe springs into a different alignment.
    Next time around, mount the two components into their clamps and to the sled, and just barely snug up finger tight so that both components can still rotate within the clamps and the clamps can still pivot on the sled. Basically you are fixing those components to the plane of the sled and a loosely parallel alignment, but not constraining them in other dimensions. Then attach the pipe to the fittings loosely and eyeball everything. Pay attention to the banjo fitting and make sure it's aligned onto the check valve surfaces. Move the accumulator and pump as needed to make it perfect. Then gently snug up the fittings by hand. I think you'll notice that everything settles into whatever arrangement is necessary to align the fittings. Once satisfied, snug up the fittings all the way, and only then tighten down the mounting clamps.
    If at any point before final snugging of the fittings, you notice that it's not possible for everything to settle into place, it suggests that the pipe is maybe bent or cockeyed. Might be possible to carefully correct that by tweaking the pipe, but I'd be wary of anything that requires serious manhandling. May also be possible to enlarge the holes on the mounting sled or clamps to let the clamp brackets move slightly, and you can also shim the clamps with washers if needed.
    If the pipe is really messed up, there are Ferrari-specific kits to replace it with stainless braided flex tubing. Then you remove the "rigid" misalignment effect of the pipe completely. I think I have one of those kits in my parts bin, bought as insurance in case I ran into issues with the pipe when replacing my 328's fuel pump and accumulator. I can dig it out if you want more info.
    I don't know that I've ever seen torque specs for fittings with sealing washers. Normally I go by feel. After the parts all make contact, a gentle twist of the wrench is usually enough. You should feel the copper washers "yield" as everything comes together. I've never paid attention, but estimate it's no more than 1/4 turn after contact is made. Perhaps someone else has better guidance on that. But for sure, having the fittings aligned before you tighten down is super important. The washers are there to make a final seal, not to compensate for misalignment.
    Rifledriver and rwbolt1 like this.
  12. rwbolt1
    rwbolt1 Karting
    Sep 10, 2006
    215
    Boerne, TX
    Rodney Bolt
    Rifledriver and S219, y'all were right. Definitely was an alignment issue. Before starting all over again, probably for the 5th time, I ordered 2mm copper crush washers (thank you Steve M. for that tip) and a new banjo cap nut. I tightened up all connections BEFORE locking the fuel pump and accumulator down in their cages. Sure enough, they were not parallel. Nowhere near, in fact. After following your recommendation, all worked out perfectly. No leak! I'm relieved. So is my wife who was threatening me that I was going to have to park the car outside. Thanks much for everyone's input.
  13. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    Cool, glad it worked out. It all makes sense based on your description.
