Fuel pumps and filter | FerrariChat
Discussion in '206/246' started by charlespoelmans, Feb 28, 2011.
  1. charlespoelmans
    Jan 4, 2009
    12
    Netherlands
    Hi,
    I have a 246 GT with the double Bendix fuel pumps, however somebody removed the original fuel filter with glass bowl and replaced it for an inline Weber filter.
    I now have a original filter (Fispa with glass) but don't know where I have to mount it.
    Does anybody have a picture or knows where to mount the filter?
    Thanks,
    Charles Poelmans
  2. Dino Club Germany
    Dino Club Germany Formula Junior
    Nov 10, 2008
    549
    Germany
    N. Schumacher
    The filter is close to the Bendix pumps.
    The fuel line goes from the second pump 90 degree bended upwarts to the filter.
    There is a metal braket with two threads for the screw fixation in the frame behind the seats which comes through the fiberglass sheet towards the engine compartment.
    Best visible from below.
    Regards
    Nicolai
  3. charlespoelmans
    Jan 4, 2009
    12
    Netherlands
    Thanks a lot.
    I now have Bendix pump with German subscription on it is this correct?
  4. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    yes, correct, PM sent...
  5. charlespoelmans
    Jan 4, 2009
    12
    Netherlands
    One more question.
    I looked at the firewall and there is a rectangular hole about 20 cm above the chassistube ( the tube that runs straight from front to rear).
    The hole is only in the insulation but there are no holes in the fiberglass.
    Because of the support that is mounted to carry the pumps I guess that this car came with the double pumps. There was also 1 pump mounted but I want it to be original .
    Is it possible to discribe exact where the filter is mounted?
    I see you are from Germany, do you know where to get genuine Dino parts ( I'm also interested in 250 parts)?
  6. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
  7. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    #7 GermanDino, Feb 28, 2011
  8. charlespoelmans
    Jan 4, 2009
    12
    Netherlands
    This really helped me , thanks for the picture and help!!
  9. pk246gt
    pk246gt Karting
    Apr 4, 2006
    169
    Adelaide, Australia
    Paul
    #9 pk246gt, Mar 1, 2011
    Hi Matthias,
    Can you tell me whether the insulation (and top trim) on the firewall panel in the image is original, and what the panel is made from please.
    I have noticed that some cars appear to have a smooth finish, some a kind of ripple paint (see image from a local car), and some appear to be a metal panel.
    What was original, particularly for the E/ 02424.
    Thanks for your comments.
    Regards,
    Paul.
  10. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    Hello Paul,
    no, it`s not original. The restauration of #01406 was done a couple of years ago and we had to replace insulation. So no panel.
    Your picture looks pretty original to me. That`s what you should copy for #02424.
    Regards Matthias
