Fuel Sender failure | FerrariChat
Fuel Sender failure
Discussion in 'Technical Q&A' started by Mr Mezzanotte, Oct 29, 2006.
  1. Mr Mezzanotte
    Mr Mezzanotte Formula Junior
    Aug 22, 2006
    651
    If I've got a full tank of fuel, and gauge is on empty and the low fuel warning light is on, has the sender unit failed on my 22k mile 11 year old 456GT ?
    Is this a big job to fix ? and how do you go about it - under car, of from car interior or boot ?
  2. chiefpilot
    chiefpilot Rookie
    Jun 28, 2004
    28
    Not a big job. Go through the trunk. Siphon out the tank. Sender is a float type and readily available. You will need a large spanner wrench to loosen the panel that the float is connected too.
