Fuel sender NOS or used? | FerrariChat
Discussion in '206/246' started by exotic30, Aug 15, 2016.
  1. exotic30
    exotic30 Karting
    Jun 22, 2008
    200
    #1 exotic30, Aug 15, 2016
    Does anybody know where to find a NOS or used Dino fuel sender? Top looks like this one (not my pic but from the dino restoration site).
  2. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I think your best option is to rebuild it, the sensor can be replaced and recalibrated with the guage.
    I've not found an OEM source for these although there are FIAT sensors from the era which can be used for parts.
  3. dm_n_stuff
    Dec 10, 2003
    43,746
    26.806311,-81.755805
    Dave M.
    #3 dm_n_stuff, Aug 16, 2016
  4. exotic30
    exotic30 Karting
    Jun 22, 2008
    200
    Sorry I'm actually looking to use this on a BB but it shares the same part with the Dino...
    You see it on the BB and it's the first thing on the gas tank side when you open the clamshell...
    The one I have has been bastardized with a DOT return line? welded on.
    And it's not like the one shown in the picture, that is a generic part which was on Eurospares for 50UKP but recently they increased to almost 200UKP.
  5. dm_n_stuff
    Dec 10, 2003
    43,746
    Dave M.
  6. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    I doubt they'll have it, I tried...
    The pic is a modern replacement using an oe style top so you can't tell. Good option I think.
    I re-plated the original top but had everything below replaced and calibrated.
  7. exotic30
    exotic30 Karting
    Jun 22, 2008
    200
    #7 exotic30, Aug 16, 2016
    I have tried GTCP in the past they didn't have it...
    I need the top only as well, mine has been modified. See attached.
  8. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Oh dear.
    Most other FIAT fuel senders with this style of lid have the built-in pickup so finding a new top that doesn't need modification is tough.
    I'd strip it, weld up the hole, have it replated and put in a modern sender.
  9. pshoejberg
    pshoejberg Formula 3
    1,827
    Denmark
    Peter H
    I have also been on the lookout for a NOS fuel sender for 3 years with no luck. I have installed an aftermarket one that works fine, but I have kept the old one for rebuild as mentioned above using the old restored top and changing out the sensor. This is a perfect winter project.
    Regards Peter
  10. 1974308gt4
    1974308gt4 Rookie
    May 1, 2016
    43
    Thomas
    seems I have the same winter project. beside a "few" more ...
  11. pshoejberg
    1,827
    Denmark
    Peter H
    That top can most likely be fixed. You have to plate it anyway, so removing that pipe and welding in a piece of metal should be feasible....great winter project.....-:)
