Fuel System Cleaner | FerrariChat
Fuel System Cleaner
Discussion in '360/430' started by Zecafureca, Aug 29, 2012.
  1. Zecafureca
    Zecafureca Rookie
    Jun 17, 2012
    36
    Boston , MA
    Aruj
  2. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    This article reads like a STP advertisement. FYI Premium fuel from some stations contain a "cleaner".
    I think a bigger issue to consider is the instability of ethanol blended gasoline. Ethanol is an alcohol and thus absorbs water [ hygroscopic ]. 100% gasoline has a shelf life in the 1-2 year range (depending on many factors I dont recall), and ethanol blended gas (E10 aka 10% eth) is in the few month range (90 days by some "experts" for Phase separation to happen).
    http://www.fuel-testers.com/expiration_of_ethanol_gas.html
    http://media.channelblade.com/Boat_Graphics/TemplateSites/DTS/DealerLibraries/241/ethanol.pdf
  3. Zecafureca
    Zecafureca Rookie
    Jun 17, 2012
    36
    Boston , MA
    Aruj
    Hi Trent. Thanks for the info. Right now, I'm using Sunoco 93, the highest octane around metro Boston (not sure about ethanol content)... will check. Regarding the fuel system cleaner; the car has only 7k miles and I drive 1 to 2 times a week for about 10 to 30 miles (half city, half highway). Starts fine / idles fine... runs like a charm. But if I leave car without running for about two weeks, it hesitates briefly before idling back to normal. So I thought since the previous owner never used any fuel injection / system cleaner, I was just wondering what is the best brand to use.
  4. Trent
    Trent Formula 3
    Dec 10, 2003
    2,013
    Indialantic, FL
    Trent
    As far as your "hesitates briefly before idling back to normal", I wouldn't worry about this. It is my experience that any internal combustion engine that sits for extended periods of time without operation has a harder time starting the first time.
    I dont use cleaners in any of my vehicles. I do use stabilizers for vehicles that sit for prolonged durations and thus have aging fuel. I also avoid ethanol as much as possible, but its hard with only one station here locally that does not add ethanol.
    Ethanol also reduces gas milage because it has less energy content than gasoline.
    Ethanol is used to increase the octane of the gasoline. This does not mean that 93 octane E10 is >93 octane, it means that without the ethanol it would be ~91 octane (just guess). So if you buy 93 octane non-ethanol then they use other methods to increase the octane.
    One last point; 93 octane fuel has slightly less energy content than say 89 octane fuel, thus less milage.
  5. JaguarDriver
    JaguarDriver Karting
    175
    Atlanta, GA
    Dick Maury
    As mentioned, most of the major brands of Premium have a detergent additive. I have been working on cars since before fuel injection was common place. Injectors used to clog up and a cleaner was needed. There are some very stong potent cleaners but these are not for the non-shop situation. The best one over the counter is a brand called 44K. One can in the gas tank is all it takes. That is if needed. If not needed, it won't hurt anything. Not affiliated but a happy consumer.
  6. djantlive
    djantlive Formula 3
    Jun 30, 2005
    1,015
    I think you are referring to BG44? I heard it's pretty strong and effective. Commonly used by repair shops.
    I also believe detergent is not required on modern gasoline, which is formulated with a high detergent content. I used Chevron's Techron and Gumout in the past and neither made much difference. Maybe older cars with over 90k miles may see some benefit.
  7. JaguarDriver
    175
    Atlanta, GA
    Dick Maury
    BG is the company name and 44K is the product, we are talking about the same stuff. Techron and Gumout are no where near as strong as the 44K product as far as the injector and carbon buildup cleaning. I have actually seen 44K loosen up enough carbon buildup on the inlet valves that it coated one side of the spark plug. (Not on a Ferrari)
  8. deeprivergarage
    deeprivergarage Formula Junior
    560
    S of Fort Worth
    Jerry
    I am not a chemist or an engineer.
    However, all of these types of products and chemicals are required to have a Material Safety Data Sheet and a CAS Number. The MSDS contains a lot of information.
    You can Google search a product or chemical for its MSDS and CAS number.
    This information will tell you what is actually in the brand of cleaner you prefer.
    Most of the underlying chemicals have common names like naphtha, mineral spirits, kerosene, or Stoddard solvent.
    The "active" ingredient may have a technical chemical name as well, which can be confusing.
    The difference between different brands may also be the percentage of the "active" chemical used in the total mixture. The percentage range will/may be listed in the MSDS.
    I think using these cleaners have made my car start easier and run smoother. I use a cleaner and/or fuel stabilizer every two or three fill ups depending on how much I drive the car.
    Jerry
    DRG
  9. Zecafureca
    Zecafureca Rookie
    Jun 17, 2012
    36
    Boston , MA
    Aruj
    I was running low on fuel on Sept 2nd , and the nearest station was a Mobil (never used before). I filled 1/2 tank of "93 octane" since I did not know the quality of the fuel. Yesterday (Sept 9), it would crank and no start. Knowing that we don't suppose to force crank...I waited 1 minute, then it started ok. RPM up and down for 4 seconds....then went back to normal idle. This was the first time the engine would not start at first try.
    I had ordered the BG 44K cleaner on-line (eBay) as I can't buy / find over the counter in Boston area. The only place that uses the BG products is Midas, but they don't sell to you: only use for their services.
    With only 2 bars of fuel left, I took to my regular Sunoco station, poured the can of 44K and added 93 gas (by-the-way: all stations in Massachusetts has 10% ethanol) to treat 20 gallons of fuel ,recommended by BG. Drove 150 miles and when drove back home, the idle was steady "frozen" at just over 1000 RPM, very good and smooth!. Will give another update when start the car cold this week.
  10. Mark from Ork
    Mark from Ork Formula Junior
    May 29, 2007
    449
    Miami Biatch
    I use a bottle of the Techron stuff in all my high performance cars once every 3-5K thousand miles.
    Personally I swear it works. Everything just seems to run better and smoother after throwing it in. Maybe it's all in my mind. Maybe not. Either way, works great in the 360 IMO.
  11. mikeyr
    mikeyr Formula 3
    Jun 17, 2004
    2,154
    Santa Barbara, CA.
    Mike Rambour
    best cleaner is good quality fuel (I prefer Chevron) and driving the 360 daily. Its amazing the difference in how great my car is running after 2 months of daily driving.
  12. av2
    av2 Formula Junior
    May 22, 2008
    478
    S. California
    #12 av2, Sep 12, 2012
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,611
    The Brickyard
    The Bad Guy
    In my opinion, unless you are using the cleaner in every single tank since new, you are wasting your money. And even then, I still think you are wasting your money.
    If you want your fuel injectors cleaned out properly, they need to be removed and sent to a shop that specializes in cleaning injectors.
    Have a read of this article, where they actually tested the fuel system cleaner, to see if it works. http://www.importtuner.com/tech/impp_1106_fuel_system_cleaners/viewall.html
  14. Mark from Ork
    May 29, 2007
    449
    Miami Biatch
    Speaking strictly from experience with Techron, I think this stuff is truly made for high performance cars.
    If you stick it in some 8 year old Hyundai SUV, I don't know what magic it's gonna do for you, but in the 360, I feel a difference.
  15. fgg
    fgg Karting
    Jul 5, 2005
    143
    Dearborn, Michigan
    Frank Guido
    Used Techron in my Mondial t (89) recently. Car seems to run much smoother with it added. Just an FYI.
  16. Zecafureca
    Zecafureca Rookie
    Jun 17, 2012
    36
    Boston , MA
    Aruj
    The car was sitting for about 3 weeks. I started it a few hours ago...what a difference! No hesitation, steady idle when cold, and running great. So, for all folks on similar situation; yes, the BG 44K did help big time. Note that you must pour one can while filling up and try to use the entire tank on the shortest period of time (drive the most miles as possible), so the chemicals in it perform better throughout the fuel system. I bought my 44K at eBay:
    http://www.ebay.com/itm/BG-44K-BG44K-Fuel-System-Cleaner-Power-Enhancer-1-Can-With-Funnel-/280947916638?pt=Motors_Car_Truck_Parts_Accessories&hash=item4169ccff5e&vxp=mtr
    The seller is a Top Rated Seller, and the can comes with the plastic funnel.
    Thank you all for your previous reply :)
  17. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    Agreed Ernie. Inneficient injectors and gummed up valves cannot be repaired by using an Additive. If there is a mechanical defect it needs repairing.
  18. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Clearly you're not familiar with the Rislone product line. They offer 6, 8 or 12-cylinder rebuild solutions in a can. Amazing non-results... :)
  19. rustybits
    rustybits F1 Rookie
    Jan 28, 2007
    2,509
    Somewhere, anywhere
    Eddie B
    :) wow! Must get me some of that! My wife's cooper s has just dropped compression on cylinder 3, I'm suspecting the common burnt exhaust valve issue, but I think I'll stick a can of something in there and rev the crap out of it rather than pulling the head?
  20. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
  21. Zcobra1
    Zcobra1 Formula 3
    1,242
    So Cal
    Bert
    Agree. In Corvettes the fuel senders sometimes go crazy and the fix is a couple of tanks of Chevron and a bottle of Techtron. A buddy of mine had a older Honda for his daughter, would not pass smog, told him to try the above, and passed smog....
    Lastly, all the major car manufacturers use Chevron gas in their EPA test cars...must be a reason.
    Had someone else swear that they got better mileage in their big suv using Chevron., compared to Costco gas, my theory was that the timing was more advanced with better gas- thus more efficient.
