Fuel tank connection sleeve -- anybody replace just one? | FerrariChat
Discussion in '308/328' started by s219, Mar 30, 2022.
  1. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    The left side fuel pipe sleeve on my 328 appears to be original and looks awful (pic below). So when I drain the tanks to replace the fuel pump, accumulator, and other assorted lines in the next couple weeks, I want to replace that tank sleeve too.
    The sleeve on the right side was replaced about 5 years ago by the previous owner's mechanic when they had the right tank out to do some other work, and that looks great (they used the proper hose and everything). Part of me wonders why they didn't do both sleeves at that time, but oh well.
    I am wondering if it will be easy to replace just the left sleeve and have enough room to work to get the new hose piece on without having to remove the entire pipe or disturb the right side. My thinking is that if I have to wrestle the crap out of things just for the left sleeve, I might be better off removing both sleeves and dismounting the pipe for more breathing room to work (would put new sleeves and clamps on both sides in that case). On the other hand, if I can do the left sleeve in place, that saves an awful lot of extra work.
    Has anyone done just one sleeve with the pipe and tanks fixed in place? Is it even doable?
  2. kiwiokie
    kiwiokie Formula 3
    Aug 19, 2013
    1,539
    Tulsa, OK
    John McDermott
    For piece of mind I would just do both at the same time.
    waymar and Saabguy like this.
  3. RodC328gts
    RodC328gts Formula Junior
    Aug 17, 2021
    458
    Mexico
    Rod C
    IMO while you are there, change both.
    It’s easier, you don’t risk damaging one while struggling to insert the other, you have drained the gasoline. Plus you won’t need to do the other in a couple of years.
    waymar and robertcope like this.
  4. Jonny Law
    Jonny Law F1 Rookie
    3,203
    Over yonder.
    IT Guy
    I replaced all the hoses I could. Even re-sleeved the ends of the crossover pipe and fuel tank pipes to take a standard hose size.
    waymar likes this.
  5. craiggo
    craiggo Formula Junior
    416
    Redwood City
    Craig
    RodC328gts likes this.
  6. RodC328gts
    Aug 17, 2021
    458
    Mexico
    Rod C
    they don’t even publish price
  7. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    I already got a 3' stick of hose for the sleeves, was about $60 if I remember right. Took a while to find the correct stuff.
  8. jha328
    jha328 Rookie
    May 26, 2013
    18
    Australia
    I just did mine a few days ago. Might as well do both as you'll have to slide the pipe in and out of the other hose to fit the new one , a real PITA. I bought mine from SUPERFORMANCE.UK LTD
  9. s219
    s219 Formula Junior
    Aug 26, 2021
    486
    Thanks - that's kind of what I figured.
  10. Lawrence Coppari
    Lawrence Coppari Formula 3
    Apr 29, 2002
    2,191
    Kingsport, TN
    Lawrence A. Coppari
    I've replaced the one on the passenger side of my '87 328GTS. As I recall I soaped up both pieces of the pipe and the piece of hose so the hose can be slid over one pipe end far enough to get it started on the other.
    308 milano likes this.
