FUEL TANK STRAINER SOCK ON A 308 | FerrariChat
Discussion in '308/328' started by steve meltzer, Jun 18, 2025.
  1. steve meltzer
    steve meltzer Formula 3
    Sep 18, 2004
    1,219
    with Enzo 8995
    I am fairly confident that my carbs are not getting fuel because of a failing fuel pump. However, a friend of mine SAW A CLOGGED UP FUEL SOCK AS A PROBLEM ON A PORSCHE SOME YEARS AGO. NOW, LIKE A HAMMER THAT SEES EVERYTHING IN THE WORLD AS A NAIL. HE BELIEVES THAT THAT'S MY PROBLEM. HAS ANYBODY SEEN THIS? IS IT SOMETHING I SHOULD DO SINCE I WILL HAVE THE PUMP OUT ANYWAY? Thanks, Steve.
  2. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,308
    Sergio Tavares
    it is an easy remove to inspect, why guess or crowdsourced opinions?
    U can still buy them I got a Rutlands one rather than plating my old one. Remove it, evaluate and replace if necessary.
    Also the great time to flush that tank too
  3. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    Probably so thanks, Steve
  4. JC1720
    JC1720 Karting
    Jan 21, 2016
    139
    Had a similar job on my old 911 - while in there do it all, you’ll only regret it / worry about it otherwise!
  5. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    yes, too worry! s (thanx)
  6. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    I haven't scoped it out yet, but do you approach the sock from below? I would think so, but maybe from above? Any tips or pearls of wisdom
    thanks steve
    (yes, I decided to replace the sock while we're doing this, so I'm headed out there to drain the tank)
  7. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    OK, I ordered the fuel tank filter sock from GT car parts. Bill said that it's best to afix it with a bit of JB Weld. Any other thoughts? thanx s
  8. Imatk
    Imatk Formula Junior
    May 6, 2007
    768
    The filter that I'm thinking of screws into the bottom, and is a plastic cage with mesh.
    AFAIK those are no longer available which is why I replaced mine with a sock.
    Did you find the OEM part somewhere?
  9. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    no, i got the sock from GTCP. s
    Sergio Tavares and Imatk like this.
  10. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    Why not use a real sealant not just epoxy which can separate in heat expansion?
    I prefer Permatex Ultra Fuel Resistant sealant.
    Any time I hear JB Weld I suspect 1) Humour 2) Sarcasm
  11. steve meltzer
    Sep 18, 2004
    1,219
    with Enzo 8995
    No Texan worth the **** on his boots, would use anything but JB Weld. But, do you have a part number you have in mind? A lot of permatex products are fuel resistant. thanx s
    Sergio Tavares likes this.
  12. Sergio Tavares
    Nov 15, 2018
    1,308
    Sergio Tavares
    29132
    you has a choice of colors, But it should come with a gasket
    Seriously, JB Weld will NOT expand when you go driving the hot Texas day and the fuel tank has a wide temperature range that day. I fear leakings for you and fuel shall not be trifled with
