Fuel tank strap repair | FerrariChat
Discussion in '206/246' started by pshoejberg, Jul 27, 2016.
  1. pshoejberg
    pshoejberg Formula 3
    1,824
    Denmark
    Peter H
    #1 pshoejberg, Jul 27, 2016
    It's been a busy summer with too much ordinary work and too less time spent in the garage, but I manage to squeeze in a little repair project that took me one hour to perform and had a total cost of around 20$. As a lot of Dino owners know, the fuel tank strap has a tendency to break, either due to serious corrosion or due to the high grade spring steel becoming brittle after electro galvanizing. Mine broke during installation due to the latter. You can buy new straps from a well known vender but I am not sure if they will fit the earlier type of 206/246 and they cost quite a bit. I bought a strip of hardened spring steel on ebay in the following dimension: 0.5 x 50 x 1000 mm and cut two new strips of metal with ease. The old straps was then repaired as follows:
    -Grind down backside of all rivets and punch out old rivets with a steel driver.
    -Remove the old straps from the latches.
    -Transfer length and hole locations from old straps to new straps. Be very accurate, latches are slightly angled to fit the tank geometry.
    -Punch new holes in straps using small hand held sheet metal puncher (5mm) You cannot drill in this steel!
    -Install new straps into the old latches using preferably old style steel rivets and appropriate tools or a hammer.
    Voila, you have then saved $$$$ and kept another few of the original parts in the car.
    Good wrenching.
    Peter
  2. GermanDino
    GermanDino F1 Rookie
    Aug 14, 2007
    3,488
    Germany
    Matthias
    well done Peter!
  3. pshoejberg
    1,824
    Denmark
    Peter H
    #3 pshoejberg, Jul 27, 2016
  4. swift53
    swift53 F1 Veteran
    8,286
    E.S.
    Alberto
    #4 swift53, Jul 27, 2016
    Lovely work as usual, nothing less from you Peter!
    The next project, well...???
    Regards, Alberto
    PS. which e-bay? All I find is Chinese origin, of course nothing wrong, but I would prefer something from your area.
  5. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Firewall junction box?
    On the fuel tank strap repair, I bought replacements for a 308gt4 which are a little long but have the period correct (rubbish) finish and replaced one end.
  6. pshoejberg
    1,824
    Denmark
    Peter H
    #6 pshoejberg, Jul 28, 2016
    Andrew, you nailed it spot on. Engineered a drawing and started "casting work" late last night. Now left with filing the round edges, drilling a hole, prep and black paint...The knob is a modified fuse box lid knob from SF.
    Alberto, you can get the spring steel from UK (Guess the tax is the same for you whether they are member of the EU or not...-:).
    172215492042 | eBay
    Best regards
    Peter
  7. pshoejberg
    1,824
    Denmark
    Peter H
    #7 pshoejberg, Jul 28, 2016
  8. VicJano
    VicJano Karting
    Dec 17, 2011
    233
    Kingston upon Thames
    Chris O'Connor
    Peter,
    That's brilliant, well done.
    Chris
  9. pshoejberg
    1,824
    Denmark
    Peter H
    #9 pshoejberg, Jul 28, 2016
  10. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    As always impressive in the extreme :)
  11. dgt
    dgt Formula 3
    Jan 14, 2011
    1,292
    Northeast, USA & Oz
    Andrew
    Peter, you need to go into production!!!!
  12. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    The biggest problem for the firewall junction box is the heat....
    will yours resist...? What`s the material, fiberglass?
    it looks great!
  13. pshoejberg
    1,824
    Denmark
    Peter H
    It is a heat resistant phenol print board rated to minimum 100 deg C continuous heat exposure + extra strong araldite epoxy glue. This is the same type of board used for the fuse box panel in the front of my car. I believe most of my engine room will be melted before this lid is toast...-:) The board is a type Etronax MF phenol board produced in Denmark and exported to most of the world for use in high amp electronic according to a product engineer from the company I spoke to. I am serious considering making a replica fuse box lid as well since these also are NLA for the L series. I am NOT considering going into production....Others are welcome to go that route....-:)
  14. GermanDino
    Aug 14, 2007
    3,488
    Germany
    Matthias
    lovely... :)
