News
fuese box
Discussion in 'Technical Q&A' started by marmik, Feb 3, 2010.
  1. marmik
    marmik Karting
    Feb 3, 2010
    56
    Denver CO
    Where is the asscories fuese box on a 360 radio, wippers ect.
  3. 2NA
    2NA F1 World Champ
    Professional Ferrari Technician Consultant Owner
    Dec 29, 2006
    17,751
    Twin Cities
    Tim Keseluk
  4. marmik
    marmik Karting
    Feb 3, 2010
    56
    Denver CO
    What dose that mean?
  5. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,335
    Check the Owner's Manual section 'L' The latest manual I have is for the F355 where the accessories fuse is in the luggage compartment.
    You might ask at Ferrari Life dot com / 360 technical section
  6. marmik
    marmik Karting
    Feb 3, 2010
    56
    Denver CO
    I just bought the car and the manuals are about 3 weeks away. Iam used to my 348 everything seems logical. Not with this car
  8. sclja
    sclja Formula Junior
    391
    San Diego Ca
    Scott Cairncross
    #6 sclja, Feb 3, 2010
    the are two locations for fuses on 360.... #1 in under the front hood on drivers side above lf wheel behind removable carpet trim panel. #2 behind the pass seat under the carpet trim (you have to remove the phillips head screws in the carpet to remove panel. I believe you will find the fuse at the back fuse boxes...
    Scott La Jolla Audio...
  9. tech4ferrari
    tech4ferrari Karting
    Jan 22, 2010
    234
    Mt Airy N,C
    casey johnson
    fuses behind driver seat and maxi fuses beside of battery as well. there will also be discriptions on the backs of the panels as long as someone hasen't taken them off for some reason.
