Fun with Fan speed controller | FerrariChat
Discussion in '308/328' started by lesorubcheek, Dec 10, 2023.
  1. lesorubcheek
    lesorubcheek Rookie
    Nov 15, 2023
    36
    Florida
    Dan Harper
    As luck would have it, the fan speed controller was bad for the AC. At first I suspected it may be the transistor mounted in the air duct, but after swapping one of the heater fan controllers and seeing the fan worked fine, I new the problem was in the controller. I disassembled the controller and found it was a PWM type speed controller using a 555 timer chip. The arrow here points to the 555
  2. lesorubcheek
    lesorubcheek Rookie
    Nov 15, 2023
    36
    Florida
    Dan Harper
    The only other non-trivial component was a BD-238 transistor. Otherwise, the board only contains resistors, diodes and capacitors
  3. lesorubcheek
    lesorubcheek Rookie
    Nov 15, 2023
    36
    Florida
    Dan Harper
    The symptoms were the fan wouldn't turn on at all with this controller. After talking with a friend, the idea suddenly hit me that the contacts on the on/off switch may not be contacting. I checked with an ohm meter and sure enough, open circuit. Sprayed the switch area as good as possible with contact cleaner and after working it a few times, success! I observed the AC clutch also engages when the switch is turned on. Tomorrow will be a test of the AC charge to see if it has proper refrigerant charge
