360 - Funny picture while doing coolant flush. | FerrariChat
360 Funny picture while doing coolant flush.
Discussion in '360/430' started by 24000rpm, Feb 13, 2022.
  1. 24000rpm
    24000rpm F1 Rookie
    flushing my coolant, drain---add water---idle---drain---add water---idle---- drain --- add water---idle ---------. 14 times.
    Pic shows juxtaposed coolant drained from my 360. From left to right (first row only)
    1st drain, 2nd drain, 3rd drain, etc etc 14th drain.
    Interesting enough, the 10th drain is more greenish than the 9th. scratched my head......
  2. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,166
    Central NJ
    Dominick
    Thermostat opened / HVAC circuit opened up ???
  3. 24000rpm
    24000rpm F1 Rookie
    each time I made sure that the THERMOSTAT OPENED
    but I only opened up the HVAC heater once, so that could be it!
    flash32 likes this.
  4. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    7,166
    Central NJ
    Dominick
    How many gallons each time ?
  5. 24000rpm
    24000rpm F1 Rookie
    7-8 liters each time if I blew it from the expansion tank
    5-6 liters each time if I don't blow it ---- gravity drain only
    flash32 likes this.
  6. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,129
    Calif
    Brett
    Oh my god....FCA event at Laguna Seca made me have only water in my cooling system for a track weekend....what a pain in the A...next time, of course sir, Its only water in there...wanna spin off that hot tank valve and find out? Never again. Cheers!
    Extreme1 likes this.
  7. 24000rpm
    24000rpm F1 Rookie
    how did you replace all your colored coolant with water only?
  8. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,129
    Calif
    Brett
    Flush, drain, flush, drain, flush, drain....etc. PITA! took 10-12 times and still a little color, BMW blue coolant in my case, but was pretty much water at that point. You can crack the drains on the engine block but I don't really wanna open that can of worms. Just drain, hit with air to get as much as out as you can, refill with water and repeat. An airlift tool to refill is critical...$100 bucks or so on Amazon.
  9. radlu
    radlu Formula Junior
    Jun 6, 2005
    424
    What about your misfires?
  10. 24000rpm
    24000rpm F1 Rookie
    sadly, China blocked every social media app that is not "made in china". So my way of contacting trev36 is limited to emails.
    I don't know why but he isn't available other than the method of whatsapp, so I am out of ideas. I've tried vpn but it didnt work for me for some reason
    I just need to send him a CS ecu dump file and let him take a look and I've thought its the ECU software that caused this misfire.
  11. tmvatlanta
    tmvatlanta Formula Junior
    Mar 26, 2017
    389
    Covington GA
    Tam V.
  12. 24000rpm
    24000rpm F1 Rookie
    it is ! I used that as a background on purpose, to attract poeple like you!
