News
Fuse and bulb container contents?
Discussion in '308/328' started by Saabguy, Mar 31, 2015.
  1. MREUS
    MREUS Formula Junior
    Rossa Subscribed Owner
    Jul 24, 2006
    826
    Huntington Beach, CA
    #26 MREUS, Aug 1, 2015
    Here is mine. Good to know that the tool kit has the spark plugs. Interestingly enough, my container has 6 bulbs. The parts catalog says 5. Also note that there is what appears to be a fuse holder that is empty. Based on the parts catalog there should only be 4 fuses. So, I guess that is "by design".
    Here is a link to the contents:
    Ferrari 308QVUS Parts : Table 43 - TOOL KIT
  3. jaa1359
    jaa1359 Formula Junior
    922
    Did 328's also come with a working light? I don't see it listed here:
    file:///C:/Documents%20and%20Settings/jajluni/My%20Documents/Downloads/Pag%20101.pdf
  4. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Yes they did, in a plastic pouch.
  5. Labman
    Labman F1 Rookie
    Jun 25, 2010
    3,694
    Long Island, NY
    Steve
    308's as well.
  6. 328PWC
    328PWC Formula Junior
    Silver Subscribed Owner
    Mar 5, 2011
    637
    Ft. Lauderdale, FL
    Paul Cissell
    #30 328PWC, Feb 23, 2016
    Here is a picture of one.
  8. chfengr1
    chfengr1 Rookie
    Aug 17, 2004
    9
    Connecticut
    Ray
    Did you ever get a list of the contents of the fuse / bulb containers? I have an '84 308 and can list the parts if you wish.
  9. Rossocorsa1
    Rossocorsa1 F1 Rookie
    4,364
    Spending a little time on the small but important details on my 1989 328 GTB. The original foam in my bulb and fuse container needed to be replaced. It took me a little time to find the correct foam but finally did. Here is the final result.
    Rosey likes this.
  10. Saabguy
    Saabguy Formula 3
    1,601
    Shreveport, LA
  11. cheesypeas
    cheesypeas Karting
    May 28, 2008
    68
    england
  13. Rossocorsa1
    4,364
    cheesypeas likes this.
  14. cheesypeas
    cheesypeas Karting
    May 28, 2008
    68
    england
    I will post pictures of the completed job.
    These light bulb holders seem to have been standard equipment on many different Italian makes ( Alfa Romeo, Lancia, etc) . They appear to be quite common. There are currently 7 for sale on eBay. Prices range from £30 to a rather hopeful $250.
    The white plastic sheet appears to have been stuck to the bottom of the foam. It does not have holes for all the plastic bits that stick up from the bottom of the container and the size of it means that the foam would have been held away from the bottom of the container.
  15. Rossocorsa1
    4,364
    Correct. The plastic sheet is rather inconsistent with the designated holes. I’m just curious about the type of foam you used. It took me a while to find the correct foam replace. Attached is my restored case.
  16. cheesypeas
    cheesypeas Karting
    May 28, 2008
    68
    england
    I'm not trying to get the correct foam. EVA foam is also known as craft foam. It's also the stuff they use in the more expensive tool sets to hold the tools snugly and in their correct place. There are videos on youtube to show how to work with it.
    I didn't check the delivery date when buying it. It turns out it's coming from China. Delivery in a month from now. :)
    EVA Foam Sheets For Kids Craft Cosplay Model 13.7"×39" Thickness 10mm £9 inc delivery.
    Cheers.
  17. cheesypeas
    cheesypeas Karting
    May 28, 2008
    68
    england
    Labman and miketuason like this.
  18. dinoart
    dinoart Formula Junior
    465
    Westminster CA
    David
    Is there foam in the green light bulb holder? I understand that foam only came with 328 holders. Just got the score sheet & photos back from FCA National in Scottdale. Score sheet says my 85 GTS QV light bulb hoder is missing the foam. Experts out there please speak. Thank you.
  19. dinoart
    465
    Westminster CA
    David
  20. Rossocorsa1
    4,364
    I can’t honestly comment if 308’s did or not.
  21. Rifledriver
    Rifledriver Two Time F1 World Champ
    27,114
    Austin TX
    #43 Rifledriver, Nov 20, 2019
    I believe foam inserts started when the cars switched to ATO style fuses and there was no provision to hold them. I would certainly appreciate any definitive information to the contrary. If in your case there was in fact a deduction for that (many things get noted and not deducted for) and if that deduction made no difference to your award if any I'd just use it as a teaching moment and be prepared to mount a defense the next time. If it was deducted and it did make a difference in your finishing status you can request a confirmation that the deduction was indeed proper. You are missing some light bulbs and they would have been justified in taking issue with that.
    Enough questions like this come up at each event it should provide most entrants and most judges to go home and study yet another thing we have no perfect answer for.
    I would never have taken a deduction for that. It is my belief there is insufficient knowledge on the topic to justify it. Knowledge of these cars in minute details is a moving target. Ferrari did few things consistently and it is not our goal to force them into cookie cutter patterns. Those inconsistencies are one of their attractive qualities.
    BTW The color of the holder is meaningless. By that time one car had green, the next car down the line had yellow etc.
  22. Rifledriver
    27,114
    Austin TX
    Looks very nice but I think the fuses were poked into the free areas of the foam and not stuck in at the periphery. Makes no difference, just an observation.
  23. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    11,170
    South East
    Jimmie
    You must be so incredibly unhappy with the deduction to be hassling so quickly !
  24. Rifledriver
    27,114
    Austin TX
    I would not define it as incredibly unhappy or hassling, more like curiosity and a desire to understand. Its been nearly 2 weeks.
  25. Rossocorsa1
    4,364
    You’re correct. They were poked. I just set them up that way to minimize the foam getting worn.
  26. dinoart
    465
    Westminster CA
    David
    That's correct. No hard feelings. Just want to know what's right. I made the cut off at 97 and went on finished the Coppa Bella. I was grateful that the judges didn't knock off for other things that questions were raised. It's a learning process and move on.
  27. Rifledriver
    27,114
    Austin TX
    Congrats. My other half runs the Coppa Bella.
    Rossocorsa1 likes this.
  28. Rifledriver
    27,114
    Austin TX
    In the future, remember you are your cars advocate. Do not hesitate to try and prove your point when those things come up. If you show it again and the same comes up tell them you have researched it and cannot find evidence the pre ATO fuse cars ever had foam. As judges we really need to be able to prove or support our deductions.
