Fuse Box Access - High Beams Don't Work | FerrariChat
Discussion in '456/550/575' started by markbnj, Sep 20, 2007.
  1. markbnj
    markbnj Karting
    Feb 25, 2007
    62
    Central New Jersey
    I'm having trouble opening the fuse box panel under the passenger side dash of my 550. Any tricks to opening it up? Neither of my highbeams work, nor does the dash indicator come on. I want to start troubleshooting with the high beam fuses. Any other thots?
    Thanks.
  2. dsd
    dsd F1 Rookie
    Nov 19, 2006
    4,271
    Northern Virginia
    The Panel has two twist lock bolts. Just turn them 90 degrees and they pop out a bit, then just pull. Be careful not to get your finger caught against the underside of the dash (experience here).
  3. markbnj
    markbnj Karting
    Feb 25, 2007
    62
    Central New Jersey
    Fasteners were tight on fuse panel so I used a small hammer to knock them loose. Fuses ok for highbeams. I'll check the bulbs next. After that, I think it's a trip to mechanic to check the switch on the stalk. Any other ideas/suggestions?
