Fuse Box door on the floor | FerrariChat
Discussion in '308/328' started by Ersel, Nov 20, 2024.
  1. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
    It seems my fuse box leather door does not want to stay in place.
    It has the Velcro’s on the door and on the car but I must be missing a bracket that holds the right Velcro on (fuse box side).
    Can someone snap a pic and show me what I’m missing—an “L” bracket?
  2. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
    I can't seem to edit my post, but someone screwed the right velcro thing to the wrong spot and I must be missing a bracket--thanks!
  3. Anthony Rapuano
    Anthony Rapuano Karting
    Aug 16, 2022
    211
    CT
    Anthony V Rapuano, Jr.
    Please indicate the model and year of your 308. The fuse panel cover was secured with different types of fasteners depending on the year of manufacture. Believe only the later cars used velcro-like attachment.
  4. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
    My car is an ‘83 QV
  5. GordonC
    GordonC F1 Rookie
    4,163
    Calgary, AB, Canada
    Gordon
    Not quite the later cars - from ~June 1984 production (last of the 1984 QVs and 1985) Ferrari used two Tenax fasteners to hold on the fuse box cover panel (Tenax are the same type of button-head fasteners as used on the GTS' roof panel vinyl cover)
    Gordon
  6. waymar
    waymar Formula 3
    Sep 2, 2008
    1,354
    Northeast, PA - USA
    Wayne Martin
    I used two heavy duty magnets on my ‘82 308GTSi
  7. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
    I seem to be missing the right bracket that holds the tenax fastener on the dash side. Just looking for a photo of that area so I can see what I’m missing. Thnx!!
  8. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
    Can you show me how you mounted the magnets please
  9. Imatk
    Imatk Formula Junior
    May 6, 2007
    769
    On mine, an '82, the velcro attachment is not where yours is. It's directly under the fuse panel. Basically right where the corresponding velcro piece is located on the leather fuse cover. So it's attached into the carpeting, not on the box itself.
  10. barry308QV
    barry308QV Rookie
    Oct 29, 2011
    22
    does this help? Mine is an 85 RHD and only had velcro until it failed and a PO added screws. Fed up with that I added the Tenax pin.
    Ersel likes this.
  11. Imatk
    May 6, 2007
    769
    Ersel likes this.
  12. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
  13. Imatk
    May 6, 2007
    769
    If your cover somehow has that in that particular configuration then it's probably fine. I know different years have differences.
  14. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
    Unfortunately my cover doesn’t work with my configuration, so that’s why I’m guessing it’s a bracket issue
    Imatk likes this.
  15. Anthony Rapuano
    Aug 16, 2022
    211
    CT
    It appears that the velcro tab on the fuse panel cover (second picture, with the silver rivets) is on the wrong side of the tab. The way it is positioned currently, it will not engage with the corresponding velcro tab on the lower part of the fuse panel (shown in the first picture). It seems that the tab on the fuse panel cover needs to be repositioned so it is opposite its current position. That way, when you put the fuse panel cover into place by sliding in the upper edge, the tab on the fuse cover will be facing upward and will be able to engage with the tab on the fuse panel, which is facing downward. Have you checked the postion/orientation of the velcro tabs on the other (left) side of the fuse panel cover? I wonder if a past owner made a failed attempt at a repair.
  16. Ersel
    Ersel Karting
    Dec 16, 2003
    53
    Bay Area, Calif
    Eric
    The left side is correct on the door. It's the bracket on the right side of the dash that doesn't align to the factory door. Unless I have the wrong door/cover. That's why I need a pic of a '83 or '84 QV so I can see what the underside of the door/cover and the dash side looks like (right). thanks
