Fuse box/relay layout info? | FerrariChat
Discussion in '308/328' started by Alden, Feb 10, 2016.
  1. Alden
    Alden F1 Rookie
    3,380
    Central Florida
    #1 Alden, Feb 10, 2016
    Is there a diagram for the fuse box/relay layout for the 308/328's like the one below for Mondials?
    I put together replacement relay/fuse kits for our Mondials and have a few requests to do it for other Ferrari owners. It certainly improves the electrical function on the cars!
    Any help appreciated.
    Alden
  2. rkljr
    rkljr Formula Junior
    May 16, 2011
    723
    South of Boston, MA
    Richard
    Not as pretty but yes. It might be in the FSM or maybe on the fuse box cover. I do not have either handy at the moment but I will check later unless someone beats me to it.
  3. BigTex
    79,325
    Houston, Texas
    Bubba
    It's on the dash panel, the legend...I'll look for it tonight.
  4. Robz328
    Robz328 F1 Veteran
    6,299
    ATL, Georgia
    Rob Hemphill
    Nice rendering. 328 has a diagram on inside of the dash cover in front of the panel.
  5. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,585
    Argent/Brasil
    Guido
    308 has NO fusebox like 328 or mondial. 328 is turned around with the fuses below.
    Diagram for the urly 328 are the same as Mondial QV and 3.2.
    Later models 328 have diffirent diagrams, more like mondial t...but there are still diffirences.
    For the layouts others will help.
    Guido
  6. Alden
    Alden F1 Rookie
    3,380
    Central Florida
    Thanks, Guido and everyone else!
    So all the relays and fuses are the same type and count? That is the info I need so I can put together sets for simple replacement. A diagram to help owners DIY is necessary too.
    Alden
  7. Alden
    Alden F1 Rookie
    3,380
    Central Florida
    Bump for any additional info, a list and/or pic would be great. Thanks all!
    Alden
  8. samsaprunoff
    samsaprunoff F1 Rookie
    4,401
    Edmonton, AB Canada
    Sam Saprunoff
    #8 samsaprunoff, Feb 12, 2016
    Good day Alden,
    There are some slight differences in the 308 models in terms of fuse sizes/loads and also relays. I would suggest that you download the various owner's manuals and go through them to see where the commonalities and differences lie. Attached is a pic from one of the manuals.
    The fuse blocks are the same size and contains the same number of fuses (9 fuses per block and there are two blocks... one white and one black) for all of the 308 and 512BB/BBi cars. The differences here are the fused circuit loads and fuse sizes. Also, the 512BBi's have a separate little 2-fuse block for the fuel pumps.
    Cheers,
    Sam
  9. Ferraridoc
    Ferraridoc F1 World Champ
    Jun 20, 2012
    17,107
    Gold Coast, Aust.
    Patrick
    Hi Sam,
    Your inbox is full. I note Simon has a set of your fuse blocks - are they back in production?
    Cheers
    Patrick
  10. Alden
    Alden F1 Rookie
    3,380
    Central Florida
    Thanks, Sam.
    Since the All Ferraris database is down for the count, any suggestions about where to source the manuals?
    Alden
  11. Alden
    Alden F1 Rookie
    3,380
    Central Florida
    Bumping this for any info on the 308/328 or other Ferrari cars.
    I got a nice diagram for the 308 GT4 from Afterburner (Thanks!) and should have relay sets available for that model soon.
    Alden
  12. onboost
    onboost Formula Junior
    Apr 13, 2004
    758
    DC Metro area
    Bumping again..
    Alden, are you doing a diagram for the 308 such as what you've done for the Mondial?
    Thx
  13. Alden
    Alden F1 Rookie
    3,380
    Central Florida
    I have the 308/GT4 ready to go, need info on the 308/328.
    Alden
