Fuse for Taillights on 550? | FerrariChat
Discussion in '456/550/575' started by Genyosai, Nov 6, 2013.
  1. Genyosai
    Genyosai Formula Junior
    May 28, 2008
    501
    SC
    Nicholas
    Is there a fuse for the taillights on the 550? I'm having intermittent issues with park lights, fog lights, instrumentation lights, and license plate lights not working though the fuse for this circuit is good. But now I have no taillights which has nothing to do with this circuit, or at least the manual doesn't say so.
    Looking in the manual, I don't see anything clearly listed as taillights. I do see a relay called "External lights", however. Are the taillights on this circuit?
    Headlights work, signals work, hazards work, dome lamps work. That's it.
    Thanks.
  2. Genyosai
    May 28, 2008
    501
    SC
    Nicholas
    If anyone else ever has this same issue, the relay labeled "external lights" controls this circuit.
  3. 00 550
    00 550 Formula Junior
    Oct 20, 2009
    412
    FL
    That guy
    I had intermittent taillights not working. Ended up being the red power wire in one of the harness connections in the tunnel. After multiple attempts at securing harness (even with a zip tie to make tight) decieded to snip wire on both sides of harness and permanently splice. No problem since.
