Gallardo and EPC warning | FerrariChat
Discussion in 'LamborghiniChat.com' started by avie, Sep 5, 2011.
  1. avie
    avie Rookie
    Nov 26, 2009
    5
    I have a 2010 Gallardo and I just started getting an EPC warning light. Had it twice so far. Turning off the engine resets it. This warning isn't described anywhere in the owners manual as far as I can tell. Any ideas what's up? Car/engine functions normally.
  2. djantlive
    djantlive Formula 3
    Jun 30, 2005
    1,015
    That's a check engine light. You can have the fault code read by any shop or even do it yourself with a $40 OBD2 scanner.
  3. drjohngober
    drjohngober Formula 3
    Jul 23, 2006
    2,040
    Cville and Gbury Tex
    Dr.John Gober
    Check gas cap- make sure it is tight.
  4. avie
    avie Rookie
    Nov 26, 2009
    5
    I just so happen to have VCDS (long time Audi owner) and it worked perfectly to pull out the OBD-II codes. It is reporting a P018C, which according to the Gallardo service manual I found says "Fuel Rail Pressure Sensor, signal voltage < 0.2 V." Does that sound like one of those transient gas cap type problems or something more serious?
  5. djantlive
    djantlive Formula 3
    Jun 30, 2005
    1,015
    has the car been sitting for a while? if so, may be it's caused by low voltage as a result of weak battery
  6. avie
    avie Rookie
    Nov 26, 2009
    5
    The car doesn't get daily use, but the battery seems OK. Plenty of starting cranking power, for example. I suspect it is something else but will watch to see if the error occurs when the battery is definitely OK. Thanks for the idea.
