Gallardo oil change | FerrariChat
Gallardo oil change
Discussion in 'LamborghiniChat.com' started by happyboy, Jun 21, 2009.
  1. happyboy
    happyboy Rookie
    Apr 30, 2009
    35
    Santa Barbara, CA
    FARHAN MIRZA
    bought my 2004 Gallardo 3 months back and the oil change was completed by the dealership. Does it matter what brand of oil I use to top off about 1 quart. I asm planning on using Mobil but I am not able to verify what brand the dealership used for the actual oil change. I dont want to change the entie oil in 3 months when only a top off of 1 quart is needed.
    The grade is 5W 40 which I will use bt dont know the brand used. Do I have to use what is stated in the book or Mobil 5W 40 be okay
  2. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    The oil Lambo recommends is expensive Agip 5w 40,(I do not think many dealers use it) and I did buy it and use it for my first oil change. I went with Castrol after that, and I do not think it will cause any problems mixing oil since I have had to to just that in many cars.
  3. Arjun
    Arjun Formula Junior
    Feb 26, 2006
    330
    Find out what brand oil is in your car and use that brand. Never mix oil brands - the differences in additives can break the oil down i.e., no protection for your engine. Its ok to mix different viscosities of the same brand but not different brands of the same viscosity. If you can't find out from the dealer what oil they used, do another oil change with the type of oil you want to use. Look at it this way, the cost of an oil change in this case is nothing compared to the cost of a destroyed engine ;-)
  4. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    I have been told by a reputable mechanic to pick a good oil and just stick with it, do not jump around from one oil brand to another.
  5. Carnut
    Carnut F1 Rookie
    Nov 3, 2003
    3,797
    Gladwyne PA
    Morrie
    I have used different oils when just a little was needed for years, and never had a problem, I can only speak from my experience.
