Gallardo turbo update | FerrariChat
Discussion in 'LamborghiniChat.com' started by G-force, Mar 28, 2005.
  1. G-force
    G-force F1 Rookie
    Aug 4, 2002
    3,053
    so california
    wayne skiles
    Just made my weekly call to Jason.
    He said after they pulled the heads he was surprised to find
    aluminum cylinder walls. Looks like he'll probably bore and hone
    and insert steel sleeves like every other high performance
    engine that will see some strong abuse. Result should be something more
    durable than the factory produces.
    I knew to do this right would be a project but that is the only way
    we'll have it.
  2. TexasF355F1
    TexasF355F1 Seven Time F1 World Champ Silver Subscribed
    Feb 2, 2004
    72,482
    Cloud-9
    Jason
    Awesome. You definately want to do it right the first time. The time away from the car, will be all made up once you get it back.
  3. jbsmooth1
    jbsmooth1 Karting
    Jul 8, 2004
    117
    Bethesda, MD
    Jon Bresler
    What kind of power are you lookin to make with that setup. It sounds awesome, cant wait to see pics!
  4. superX
    superX Karting
    Nov 2, 2003
    100
    Cary, NC
    Dennis Briddell
    they were aluminum with a nikasil coating, which is an extremely hard and durable surface. I'm not sure why they want to change that unless the liners are too thin for the power levels you had in mind.
  5. TOOLFAN
    TOOLFAN F1 Rookie Rossa Subscribed
    Mar 23, 2005
    2,807
    California
    Are you planning to increase the bore or stroke? are you going to use a wastegate or a blow off valve pressure release system? as you may know v 10's have the best crankshaft harmonics of any over head piston engines so turboing it will necesitate less attention to strenthing the powertrain it's self this will allow you to go a little crazier with the power than most people can when turboing their car just remember that power is useless with out good rubber
