News
Garage-Dri
Discussion in 'United Kingdom' started by barabus, Nov 3, 2004.
  1. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    #1 barabus, Nov 3, 2004
    I recently installed a new system for keeping your garage dry called garage-dri. http://www.garage-dri.com/.
    It's different to the usual de-humidifier in as much as it does not collect water, rather it converts the incoming air somehow, I dont really understand it but it's supposed to work.
    I just wondered if anyone else is using one and if so do they think their any good????
    Cheers.....Si
  3. tonyh
    tonyh F1 World Champ
    Dec 23, 2002
    14,372
    S W London
    Tony H
    Blimey, for a van driver you don't mind spending your folding on gadgets, Si :D
  4. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Well you gotta look after the Beasty eh Tone.
    Its funny I tell the Misses off for buying another flippin handbag and think nothing of spending big bucks on the Big F.
  5. tonyh
    Dec 23, 2002
    14,372
    S W London
    Tony H
    HEHE ! So true, Tubi for me , Gucci bag for her :D
  6. mal
    mal Formula Junior
    Jan 12, 2004
    615
    Kent
    I have looked at that, but I really cant make up my mind whether it will really work. So I would be interested in your experience with it.
    I have just installed a Ruby Dry dehumidifier, which in two days has changed the environment in my garage completely, but I still may put in the Garage dri as well to be sure to be sure!
    http://www.dry-it-out.com/rubydry.htm
    Mal
  8. GrahamS
    GrahamS F1 Veteran
    5,447
    24 hours from Tulsa
    Grandmaster G
    Not having a power point in my crummy excuse for a garage I'm struggling on the de-humidifier front.
    Has anybody any experience of one that can be powered off a car battery?
  9. mal
    mal Formula Junior
    Jan 12, 2004
    615
    Kent
    With no power it would drain the battery in no time
  10. GrahamS
    GrahamS F1 Veteran
    5,447
    24 hours from Tulsa
    Grandmaster G
    Thought so
    How about a windmill powered one then? :)
  11. mal
    mal Formula Junior
    Jan 12, 2004
    615
    Kent
    Graham - apparently you can get solar powered ones:
    ''The final option, and probably the best if your garage is separate from the house, is an airchamber. By isolating the car in a dust-free bubble and blowing filtered air through all the time, these products ensure as clean and dry an environment as possible. The air flowing through gradually removes any moisture that has adhered to the car, arresting any corrosion. The only significant disadvantage for the ordinary user is one of bulk – in a normal garage it will effectively block off shelves and tool racks around the car. Don’t be put off just because you use the car regularly; it takes a few seconds to unzip and roll back the cover and few more to replace it. If your garage lacks power, it’s possible to run them off a 12-volt battery and even to set up a solar-powered charger to keep that battery topped up.''
    This a quote from the classic cars magazine artile 'is you garage killing your car' see here:
    http://www.classiccarsmagazine.co.uk/nav?page=classiccars.specialfeatures.detail&resource=651222
    Hope this helps
    Mal
  13. OmegaSteve
    OmegaSteve Formula Junior
    Sep 18, 2004
    570
    Hertfordshire
    Steve
    Mal,
    Thanks for the info on the Rubi-dry, i've just ordered one, should be with me tomorrow. Will report back on performance if anyone is interested
  14. F328GTS
    F328GTS Formula 3
    Apr 27, 2004
    1,628
    Cambridgeshire, UK
    Nigel R
    I heard a bale of hay in the garage can be quite effective as it will absorb all the moisture in the air. As it's so cheap it might be worth a go...
  15. GrahamS
    GrahamS F1 Veteran
    5,447
    24 hours from Tulsa
    Grandmaster G
    Either that or an industrial size dessicant bag
  16. barabus
    barabus F1 Rookie
    Aug 22, 2004
    4,777
    12 Cylinder Village
    Si
    Hi Mal
    Well I can only tell you this. Before the garage-dri the bare steel of my vice would go brown obviously the damp was causing rust to form.
    However since the installation the vice remains clear, so it would seem like it's working, but like you it's hard to understand without seeing any accumulated water you don't actually know for sure.
