Garage floor cleaner | FerrariChat
Discussion in 'Other Off Topic Forum' started by UroTrash, Jun 10, 2004.
  1. UroTrash
    UroTrash Four Time F1 World Champ Consultant Owner
    Jan 20, 2004
    40,470
    Purgatory
    Clifford Gunboat
    I'm thinking of doing an epoxy paint finish to my garage floor, but it has some oil spots. Is it even possible to clean these spots with anything well enough to make the paint stick? I think to have part of the epoxy come up would look worse than no epoxy at all.
    Whats the very best thing to prep with?
  2. Erich
    Erich Formula 3
    Sep 9, 2003
    1,190
    Poway CA
    Erich Coiner
    When I had epoxy put down in my NEW workshop, the guy used pool acid to etch the concrete.
    I would use a heavy degreaser like TSP (the real thing Tri sodium Phosphate)
    followed by pool acid.
    It was cool watching the "smoke" rise as the acid was poured on.
    Erich
  3. Jerrari
    Jerrari F1 Veteran
    Jul 24, 2001
    5,469
    Michigan
    Jerry Wiersma
    Don't get it at a pool store though, they'll rape you. It is simple muriatic acid that you can get at Menard's, Lowe's, etc. You will definitely need to degrease first though as Erich mentioned as acid will not remove grease.
