Garage Heat | FerrariChat
Garage Heat
Discussion in 'Detailing & Showroom' started by simchanova, Nov 12, 2015.
  1. simchanova
    simchanova Formula Junior
    585
    Philadelphia
    Stuart
    My cars are stored in a garage with 18 other cars...24 total with very high ceilings...looking for cost effective solution to heat garage and remove moisture ,thoughts?,Stuart
  2. INTMD8
    INTMD8 F1 Veteran
    Jun 10, 2007
    6,763
    Lake Villa IL
    So around 5000 sq/ft? What type of construction? Insulation?
    Probably would just be looking at an exterior package unit, either through wall (which is what I ended up doing) or roof mount.
    I think it may be too big to go with Mini Split(s) but I am no expert.
  3. moysiuan
    moysiuan F1 Rookie
    4,187
    Canada
    I have a Mitsubishi heat pump/ac combo unit that installs like a mini split but has a ceiling rather than a wall mounted cassette. Amazing technology really, works well, has a dehumidify setting and is pretty energy efficient. My unit is a commercial unit, good to -25c, I am in Canada and have some stretches in winter that get pretty cold. Its expensive, but I understand even the cheaper heat pumps good to generally 0c can be used in very cold temp with a small electric heater add on, would make sense if your really cold temps are rare or infrequent.
  4. bocaf430
    bocaf430 Formula 3
    Jun 10, 2014
    1,361
    LI, boca raton
    Get a mini split heat pump, you will have heat and cooling
