Garage Lifts | FerrariChat
Garage Lifts
Discussion in 'Technical Q&A' started by soulkid, Dec 26, 2009.
  1. soulkid
    soulkid Rookie
    Sep 28, 2008
    25
    Looking at getting a garage lift so I can store 2 cars in the garage.
    The garage dimesnions are 5.60 x 2.44
    Anyone here know if I can fit a lift in a garage of this size?
  2. Davesvt2000
    Davesvt2000 Formula 3
    May 3, 2005
    1,144
    Central Mass.
    Dave G.
    Could you be more vauge ?
    Yards, meters, feet, what are we talking here ?
  3. Jamie H
    Jamie H Formula 3
    Aug 28, 2009
    2,425
    Puslinch,ON
    Jamie
    I was about to ask the same question.
  4. soulkid
    soulkid Rookie
    Sep 28, 2008
    25
    Sorry guy's.
    That would be meters.
  5. westextifosi
    westextifosi Formula Junior
    274
    Lubbock, TX
    Tex Timberlake
    What is the ceiling height?
  6. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
  7. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,280
    Illinois
    I have a Direct Lift. The lift will fit in the garage fine. The bigger question is can you get one car on the lift and another under it.
    I have a 328 sitting on my lift with 3 inches between it and the ceiling. I also can park a Grand Am or other sedan type under it with about 6-8 inches of clearance.
    My advice is measure your cars at least three times, add 10 cm for the lift ramps the car sits on and you will need probably at least another 15 cm clearance for the ceiling and under the lift for the second car.
    Measure many times and be sure of your measurements before buying the lift.
  8. soulkid
    soulkid Rookie
    Sep 28, 2008
    25
    I need to check exactly. I would say about 7 Foot.
  9. soulkid
    soulkid Rookie
    Sep 28, 2008
    25
    #9 soulkid, Dec 26, 2009
  10. BT
    BT F1 World Champ
    Mar 21, 2005
    15,291
    FL / GA
    Bill Tracy
    If your ceiling is 7 feet I doubt you will be able to fit a lift and get two cars parked there. 7 feet (84") would only allow about 64" for the combined height of the cars, and I don't know of any two cars that could fit in that height combined.
    BT
  11. FandLcars
    FandLcars F1 Rookie
    Aug 6, 2006
    3,057
    Tempe, Az
    Rick Schumm
    And you also need to allow for enough height to store the lift on a "stop", which requires being able to raise the lift above this stop (to release the stop) a couple inches, to be able to lower the lift back down. There would be different stop heights for different lifts.
  12. KKRace
    KKRace Formula 3
    Aug 6, 2007
    1,052
    Rockville/Olney MD
    Kevin
    Depending on the roof contruction assuming you don't have a bedroom over the garage you may be able to modify the ceiling trusses to give you more height? Also remember in order to park a second car underneth you need to be able to get the garage door open far enough for the second car to pull in. Consider a Jackshaft power opener instead of a common style and it will allow you to have the tracks on the door right up against the ceiling.
  13. Paul_308
    Paul_308 Formula 3
    Mar 12, 2004
    2,345
    Having 84" floor-ceiling clearance the solution is obvious. Get two Ford GT40 supercars. Their roof is 40" off the deck, hence the nomenclature.
    By using a 3" carbon fiber box girder to provide lift/store for the upper car, there will be a comfortable centimeters between cars, and at the ceiling.
    OK, with that solved lets turn attention to the all important lighting system. To maintain green protocol, you could use vege-candles on opposing walls, with positions and lighting completely computer conltrolled. See http://www.suite101.com/view_image.cfm/574958
    Or use solar powered LED simulated candles. This place could do dual duty as car storage, maintenance and candle ambiance for spiritual experiences while working on the car or prayer services before taking the car to the street.
  14. Irishman
    Irishman F1 Rookie
    Oct 13, 2005
    3,524
    Raleigh
    Kevin
    You're welcome!
    Though I admit and regret my folks never taught me Irish. They both spoke it well but tended to only use it when they were fighting with each other :):).
  15. ramosel
    ramosel Formula 3
    Sep 11, 2004
    1,237
    Meadow Vista, CA
    R Moseley
    HaHaHaha.... My Dad was third generation Green and knew no gaeilge. Mom was 1st generation Orange. She'd fall on the old language when very mad or very loving. So I know what ya mean. I wish I'd learned more too! If I remember, the correct response would be "ta failte rohat".
    Rick
