Garage Pics!! | Page 475 | FerrariChat
Garage Pics!!
Discussion in 'Detailing & Showroom' started by Titanboy_24, Dec 28, 2003.
  1. ducatir8cer
    ducatir8cer Karting
    Dec 25, 2014
    84
    Yes, that’s the battery tender wire. Thanks for the advice. I hate leaving the windows down. The car sits for a while between uses and I’m usually greeted by a spider or two as a result. Again, thanks for the observation and advice.
  2. AP328
    AP328 Karting
    88
    Canada
    You are most welcome. Before I knew, I used to lower the window slightly, then use painter's tape to close off the gap - what a pain!
  3. 4_Eff_Sake
    4_Eff_Sake Formula Junior
    Jul 30, 2016
    761
    Australia
    Scott
    I just bought a couple of ctek battery tenders for a couple of cars - one is a GT3. Where are you running your charger cables to that takes them through the window? I’ve read about Porsche having some sort of cigarette lighter adapter but of course, the ctek branded unit doesn’t come with that accessory, so just researching the best connection method for the GT3 in the absence of that fitting
  4. Solid State
    Solid State F1 Veteran
    9,649
    Maximus Decimus Meridius
    The new Cteks have an in-line connector so you can swap in different cable ends. I'm sure you can either buy one directly or easily assemble a lighter adapter to your unit if no better method.
    4_Eff_Sake likes this.
  5. ShineKen
    ShineKen F1 World Champ
    16,662
    Southern California
    Nostradamus
  6. ShineKen
    16,662
    Southern California
    Nostradamus
  7. colombo2cam
    colombo2cam Formula Junior
    Jan 31, 2019
    832
    Ted
    ShineKen likes this.
  8. ShineKen
    16,662
    Southern California
    Nostradamus
  9. colombo2cam
    Jan 31, 2019
    832
    Ted
    I have been very happy
  10. flat-12
    flat-12 Formula Junior
    Mar 18, 2011
    356
    Germany
  11. kryten2001
    kryten2001 Formula 3
    It'd have to make a log trip all the way from Australia!
  12. ShineKen
    16,662
    Southern California
    Nostradamus
    Asking for a friend in Brisbane :)
  13. kryten2001
    Tell you friend to keep me on his radar, but not selling at this stage. It's an absolute mint condition one and I'm not quite ready to let it go just yet :)
  14. ShineKen
    16,662
    Southern California
    Nostradamus
    Model year?
  15. kryten2001
    The one you want. 1995. Basically it ticks all the boxes.
    1995 Red over tan, has the tough to find carbon fibre seats, gated manual... Pretty much unmarked, it's a real beauty. No issues at all with it, not even a single sticky button... It's a real good one.
    GSF355 and ShineKen like this.
  16. ShineKen
    16,662
    Southern California
    Nostradamus
    :eek:
  17. omd78
    omd78 F1 World Champ
    Dec 26, 2005
    13,140
    Breda, Netherlands
    Martin
    flat-12 likes this.
  18. ag512bbi
    ag512bbi F1 Veteran
    Nov 8, 2003
    7,553
    So. Cal
    Armen
    Nice collection. A boxer is needed to fill the gap ('74-'84) of the 12 cylinders.
    flat-12 likes this.
  19. Finlander
    Finlander Formula 3
    2,328
    Sunshine State
    On my Porsches I find it best to connect directly to the battery (in the trunk under the plastic panel closest to the windshield) using the connector that comes with the Ctek charger. Then I use this additional cable so I have enough to run from the charger on the ground, to the connector on the battery. I just leave the 12-18" section thats connected to the battery, and run it under the panel that covers the battery. Now you have a simple quick disconnect. Hope that makes sense.
    https://www.amazon.com/gp/product/B00B4ELMU8/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
  20. 4_Eff_Sake
    Jul 30, 2016
    761
    Australia
    Scott
    Fantastic. Thanks for the advice and the link
  21. XSQF
    XSQF Rookie
    Apr 5, 2019
    39
    Loxo, Tadhg, Avia11 and 11 others like this.
  22. Snaponjackson
    Snaponjackson Formula Junior
    468
    INDIANAPOLIS INDIANA USA
    Chris Jackson
    Mang likes this.
  23. 4_Eff_Sake
    Jul 30, 2016
    761
    Australia
    Scott
    Is that TDF Aluminio Opaco? Or Argento Nurburgring?
  24. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    901
    Homosassa, FL USA
    Ian Joubert
    Doors are in! One is powered with remote control, the other is manual. I figured it would rarely be opened so there was no point.
    And, 60 yds. of concrete later. I poured it 6" thick. I figured a little more money in concrete now could save me $$$ and headaches later vs. doing a 3.5" pour.
    Next up is wiring, the insulation, the a/c's. The floor epoxy instructions say to let new concrete cure for 29 days prior to application.
    WJC, Boomhauer, jqpd99 and 4 others like this.
