Gas Cap Whoosh | FerrariChat
Gas Cap Whoosh
Discussion in 'Mondial' started by 123howie, Dec 6, 2014.
  1. 123howie
    123howie F1 World Champ
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    When I stop for gas and undo the gas cap I get a big whoosh. Is this normal, or should it be vented? Am I screwing the gas cap on too tight? I have a 92 Mondial. Thanks in advance. H.
  2. billh1963
    billh1963 Formula Junior
    Apr 28, 2004
    863
    Mid-state, South Carolina
    Bill H
    I don't have a T, however, that does not sound normal. My 3.2 coupes don't do that
  3. YELO T
    YELO T Formula 3
    Jul 2, 2012
    1,193
    Long Island, NY
    Jonathan
    1. Stuck rollover valve.
    2. Collapsed filler neck due to excessive pressure buildup in the gas tank.
    3. Clogged charcoal vapor filter. The charcoal filter is recommended to be replaced at about 50,000 miles according to the owner's manual, but this part is no longer available. :(
  4. ProCoach
    ProCoach F1 Veteran
    Sep 15, 2004
    5,465
    VIR Raceway
    Peter Krause
    Factory...
  5. DavidJ
    DavidJ Formula Junior
    Feb 12, 2012
    387
    Northern NJ
    David
    +1: Roll over valve.
    Vapor filter can be rebuilt/fabricated by a good mechanic/welder.
    DavidJ
  6. MondialNeil
    MondialNeil Formula Junior
    Apr 2, 2007
    427
    Bucks,UK
    Neil S Perry
    Hi
    My 3.2 has started doing this, where is this rollover valve on a 3.2.
    Cheers
    Neil.
  7. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    Mine does it depending on temp change. 5 years and 20K miles it has been doing it. Modern cars can do it too. 1987 3.2
  8. 123howie
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    Let me add to my question, can damage of any kind come from it? Do I worry about it or just let it go whoosh?
  9. B11ocx
    B11ocx Karting
    Jan 30, 2014
    56
    Manchester UK
    Jon
    You should have a pressure release upon unscrewing the gas cap as far as I am aware.
    The fuel system is pressurised. If you don't, then you probably have a leak in the system or a failed pressure vessel. Have no idea if that applies to earlier cars, but certainly my T didn't have any pressure and I had a fuel smell..... fixed the leak and the system is now pressurised. The specialist diagnosed the problem initially by the lack of back pressure at the cap.
  10. raf456
    raf456 Karting
    Jan 27, 2013
    178
    Chapel Hill, NC
    Robert Freiburghouse
    My T coupe has always done this and I have experienced no problems with the car.
  11. PV Dirk
    PV Dirk F1 Veteran
    Jul 26, 2009
    5,401
    Ahwatukee, AZ
    I believe they are designed to take a certain level of pressure. I have also heard of issues of too much pressure causing problems lately. I don't have details. Sorry to muddy the water.
  12. ozmondy
    ozmondy Formula Junior
    Oct 30, 2013
    307
    N.T, Australia
    Peter
    [+1QUOTE=B11ocx;143573993]You should have a pressure release upon unscrewing the gas cap as far as I am aware.
    The fuel system is pressurised. If you don't, then you probably have a leak in the system or a failed pressure vessel. Have no idea if that applies to earlier cars, but certainly my T didn't have any pressure and I had a fuel smell..... fixed the leak and the system is now pressurised. The specialist diagnosed the problem initially by the lack of back pressure at the cap.[/QUOTE]
  13. sidtx
    sidtx F1 Rookie
    Feb 9, 2014
    4,454
    Frisco, Tx
    Sid
    My 85 QV does this. A large whoosh sound when undoing the gas cap. My newer vehicles also do this.
    And, as part of the emissions testing, here in Texas, they actually screw on a test cap to determine if your fuel system holds pressure. Note - This is only required for cars younger than 25 years old.
    sid
  14. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    #14 hank sound, Mar 12, 2015
    Howie,
    Are you having problems at the gas pump? By problems, I mean - constant shutting off of fuel flow. Excessive pressure can collapse your fuel filler hose - causing the backwash which triggers the shut off in the nozzle.. Also, make sure that the fuel cell isn't getting sucked in (as in - - imploding!!!)
    Unfortunately, I speak from experience ! :(
    Cheers mate,
    Hank
  15. 123howie
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    Hi Hank, how are you doing, I did not see you and Rachel at the Petersen car show? No I am not having and problems what so ever, but this is the loudest and strongest whoosh I have ever heard by undoing a gas cap, but my reading the many reply's I guess it means all is really ok. Howie.
  16. paulchua
    paulchua Cat Herder
    Jul 1, 2013
    16,368
    Menlo Park, CA
    Paul Chua
    I've always had that super loud swoosh every time...last 3,000 miles.
  17. Burch1
    Burch1 Formula 3
    May 26, 2012
    1,028
    Singapore/Carmel, IN
    Greg
  18. afterburner
    afterburner F1 Rookie
    3,454
    Switzerland
    Urs STEMMLER
    Normal with the K-Jet cars - apparently for the T too; the tanks are slightly pressurised. It also indicates that your system is gas tight.
  19. Mondial 1985
    Mondial 1985 Formula Junior
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    I've had many cars of mine do that and they never suffered any ill effects from it. My cars did this based on temperature and altitude variations. Going from cold winters straight into hot summers and altitudes varying fro sea level to 3,000-4,000 feet. It won't hurt the car.
  20. hank sound
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    Hi folks,
    Under normal circumstances, the fact that - - "they have never suffered any ill effects from it", would be 100% applicable and true.
    In my case, the suction "woosh" at the gas cap inlet, accompanied by continual gas pump nozzle shut off while refilling - - and that nasty whining of my totally confused fuel pumps, certainly got my attention - - "oh ****, somethings' wrong here".
    Eugenio found it all, corrected all the F-ups, and the Court agreed. Now, it's all just a part of Rachel's history.
    Cheers, Hank
  21. afterburner
    3,454
    Switzerland
    Urs STEMMLER
    Air going out or in?
  22. 123howie
    Jul 3, 2014
    16,017
    El Segundo CA
    Howie
    Now that's a good question, I really have no idea and not sure how to tell??
  23. afterburner
    3,454
    Switzerland
    Urs STEMMLER
    Air going out would be normal as there is a pressure build while the engine runs. When you unscrew the cap slightly you can feel gas-smelling air going out, the cap will get pushed into your hand when it comes off.
    Air going in would be a problem as it will potentially lead to some hoses collapsing due to the depressurised condition of the system. While you unscrew the cap, you'd hear air being sucked into the tank, the cap would get pulled onto the neck and will be harder to take off at the end of the thread.
  24. VIZSLA
    VIZSLA Four Time F1 World Champ
    Jan 11, 2008
    41,692
    Sarasota
    David
    What were the specific F-ups (sounds like an F-Chat subgroup) were they?
    I've had it happen only once on my 77 carb GT/4 after a long time sitting in traffic on a hot sunny day.
  25. Mondial 1985
    Jun 13, 2012
    344
    Greenville, SC
    Mark Alan Day
    My "whooshes" always sucked when I opened the gas cap. They never blew.
