Buy
gas filler flap
Discussion in 'Technical Q&A' started by f355b, Mar 14, 2004.
  1. f355b
    f355b Formula Junior
    Jan 23, 2004
    445
    Little Silver,NJ
    cant open the filler flap on my 355 i have look at the fuse and tried by using the toggle in the engine compartment, still wont open.........any ideas?
  3. ShanB
    ShanB Formula Junior
    Jul 9, 2003
    547
    Tejas/Europe/Desert
    shanb
    Try very gently pressing on in fuel door while simultaneously pulling the backup fuel door cable as sometimes the plunger gets stuck on the striker plate. If that doesn't work, I would raise the car, remove the wheel & fender wells and have a look at the solenoid to see if the plunger is stuck. It sits in a bracket attached to the filler opening area and sits high inside the bodywork, but you should be able to see it.
  4. f355b
    Jan 23, 2004
    445
    Little Silver,NJ
    thank you very much, i'll give it a try this week and post a reply
