News
Gas flap problem fixed
Discussion in '348/355' started by ferraridriver, Apr 4, 2008.
  1. ferraridriver
    ferraridriver F1 Rookie
    4,092
    Bay Area Calif.
    Dave
    I had posted a while ago about replacing the OEM connector at the gas flap solenoid with T&B spade wire ends.
    I can now say after several months testing that the OEM connector was the culprit.
    Before changing the connector I had cleaned and applied Stabilant, that lasted about a month then it was back to manually opening the flap.
    I wonder how many solenoids have been replaced when corroded terminals in the connector was actually the problem.
    My gas flap now opens every time.
  3. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    Great post............. it makes sense in that corroded terminals could not carry the neccessary current to power the solenoid.
    I have mentioned before that I took every connector/relay/fuse I get my hands on and put a corrosion inhibitor on those interfaces. It does nothing but good as voltage/current can flow better throughout the electrical system. :)
  4. UConn Husky
    UConn Husky F1 Rookie
    Nov 11, 2006
    4,416
    CT
    Jay
    Great info Dave, I'll have to check mine. Although it is kind of cool to pull up to the gas station and open the engine cover to pop the gas cap...
