gas gauge | FerrariChat
gas gauge
Discussion in 'Technical Q&A' started by db4, Nov 15, 2009.
  1. db4
    db4 Karting
    Oct 24, 2009
    94
    ny
    93 348 ss no gas gauge low fuel light works where should i look firts?
  2. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    have the same problem on my qv if i ever pull the motor i'll fix it then. for now i just monitor the mileage and keep it full.
  3. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Welcome to Ferrari Chat, db4.
    Just for additional information:
    Does the low fuel light only come on when the tank is very low, or is it on all the time?
    Does the oil temperature gauge next to the fuel gauge work properly?
    Does the dashboard illumination work in the fuel gauge?
    Is the needle on the fuel gauge stuck at zero, or somewhere between empty and full?
  4. Future ferrari collector
    Oct 12, 2006
    1,795
    Hi all,
    Anyone knows how much fuel is left when that light comes on? Gauge reads about 1/8 of a tank which should equate to approx 10litres (2gal). But you know what these gauges are like. I can never get close 75litres, let alone manual's touted 82 litres even when I think I'm running on fumes.
  5. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,665
    South East
    Jimmie
    The simple assumption with most Ferraris is when the light is solid you have at least fifty miles - what does the 355 book say : 20 litres as I recall so to refill as soon as the light is solid shouldn't take much more than 60 litres
  6. Future ferrari collector
    Oct 12, 2006
    1,795
    Problem with the book is that it doesn't say anything, from the range you have to the amount of fuel that triggers the light.
  7. db4
    db4 Karting
    Oct 24, 2009
    94
    ny
    low fuel light only on when low , oil temp works , gauge lights work, gas gauge is intermittent drops to empty at will ,will work for an hour then drop to zero .
  8. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    I can only give an opinion, but to me, this sounds like a gauge problem rather than a sender problem or a wiring problem. But it would be easy (less than a minute) to pull the center console panel and check the wiring connection on the back.
  9. tazandjan
    39,167
    The reserve on a 355 is 5-5.2 gallons or 19-20 liters when the fuel low lamp illuminates. That could explain why you never get as much fuel into it as you think you should. On many cars the tank will read empty when the fuel lamp low indication illuminates, telling you only reserve remains.
    The 348 says the reserve is 5.28 gallons or 20 liters.
    Taz
    Terry Phillips
  10. AceMaster
    Feb 6, 2009
    34,777
    Ontario, Canada
    +1
  11. greyboxer
    Dec 8, 2004
    12,665
    South East
    Jimmie
    Two nations separate by a common language !
  12. db4
    db4 Karting
    Oct 24, 2009
    94
    ny
    thank you all for your input
  13. tazandjan
    39,167
    Jimmie- Six years in the UK, so I am bilingual.
    Taz
    Terry Phillips
  14. bill brooks
    bill brooks F1 Veteran
    6,050
    waynesburg,pa
    bill brooks
    i have an '87 328.
    when the yellow light comes on solid, i'd better be in plain view of a gas station.
    i ran out of gas between nowhere and not- at- all when i first got her.luckily a nice
    farmer brought over a can of premium with a flexible spout.
    he didn't even want money for the gas!
    i always put in 5gal. or so every time we leave the garage.
