Gas Mileage | FerrariChat
Gas Mileage
Discussion in 'Ferrari Discussion (not model specific)' started by AZ Ferrari Man, May 18, 2004.
  1. AZ Ferrari Man
    May 5, 2004
    19
    Tucson, AZ
    AJ
    Any suggestions on how to test? I think that the easiest way is simply take the miles you drove after filling up and take that number down, and take the amount of gallons you put in and devide it the next time you go empty (till light goes on) and devide the two. Also see how many gallons are left when the light goes on (owners manuel etc.. for that info) and make proper adjustments. Any suggestions?
    Thanks this is one of my first post and am glad to be part of the site!
    Andrew
  2. don_xvi
    don_xvi F1 Rookie
    Nov 1, 2003
    2,934
    Outside Detroit
    Don the 16th
    That's about all it takes! Drive miles, add gallons, divide.
    Drive enough miles to make it worthwhile--clowns on other forums have insisted that they'd drive to the airport & back and watch the fuel needle and determine if something had improved their mileage. Use most of the tank. Use a consistend fill technique--3 clicks is pretty normal. If you can fill up at the same station & pump, even better. But those variations in pumps are the reason to drive more miles to begin with...
    Oh, and don't be worrying about the light.
  3. beast
    beast F1 World Champ
    May 31, 2003
    11,479
    Lewisville, TX
    Rob Guess
    Welcone to FerrariChat Andrew.
