Gas Nozzle Won't Fill Without Stopping XX Times- '81 GTSi | FerrariChat
Discussion in '308/328' started by 2dinos, Jun 25, 2019.
  1. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,061
    Like the thread title says. I've gone through the evap system and breather system. The hoses. All perfect! Grumble grumble. I've got a new theory. Vapor recovery is sucking up splashing fuel during fill-up triggering it to stop.
    Any thoughts?? Thanks. FWIW, I have a good buddy with GTSi, and has same dumb problem. His mechanic has carefully gone thru all of the components on the vent side, and renewed all of the hoses. Problem still remains. Occasionally, (kinda rare) I can go to a station, and it fills smoothly. Next time this happens, I should notice the pump nozzle. I seem to recall the gas nozzle brand Weaton (?). Maybe reach out to them?
    Sure love driving it !!!!!
  2. thorn
    thorn F1 Rookie
    3,324
    Tallahassee, FL
    I have this happen occasionally with my DD. I think it's the pump, not my car. At the station I usually stop at, it never happens.
  3. johnk...
    johnk... F1 World Champ
    Jun 11, 2004
    11,278
    CT
    John Kreskovsky
    Common issue. Fill slower.
  4. Alex308qv
    Alex308qv Formula Junior
    Jul 1, 2016
    406
    PA
    Alex
    When I got my 308, an experienced tech said to fill slowly because it takes time for the levels to equalize between the two tanks via the cross pipe. I add a gallon, pause a few seconds, add another gallon, etc. Some pumps have high flow rates and if you don't go slow the pump will shut frequently or worse burp gas out the filler and all over your paint/shoes.
    Crowndog likes this.
  5. Steve Magnusson
    26,932
    Have you tried rotating the filling nozzle from the gas pump 180 degs (so the hoe end points up)? Many (including myself) have found this works much better.
  6. wildcat326
    wildcat326 Formula 3
    Dec 10, 2012
    1,803
    Chicago, IL
    Justin
    On my car, have to hold the pump handle 180 degrees vertical (basically the plastic-covered handle touching the bodywork), and then it works fine; otherwise, it cuts off every other second. And my fuel tanks and breather system are freshly rebuilt and in perfect working order.
  7. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,061
    Thank you all!
    Going as slow as possible. So slowly in fact,I can't engage first pump levers holding slot. And still kicks off. I also tried to start/stop, but that works for a few seconds - then it doesn't. I thought I've tried to rotate nozzle without success, but I will definitely try this approach again. Lastly, some stations are indeed better.:)
    Would love to know why?? My Bimmer accepts fuel from anywhere and never behaves like this.
  8. GrigioGuy
    GrigioGuy Splenda Daddy
    Nov 26, 2001
    33,433
    E ' ' '/ F
    Enzo Gorlomi
    Turn the nozzle upside down
  9. johnny308
    johnny308 Karting
    Dec 3, 2011
    151
    Greenfield, MA. USA
    Fill slowly.........some pumps are more difficult than others.
  10. V4NG0
    V4NG0 Formula Junior
    Dec 14, 2018
    705
    Charles Edward Cheese
    I had this problem on my 911. As it was described to me, the "anti-spitback valve" was faulty. The dealer replaced it ~3 years ago, and fill-ups have been problem-free ever since.
  11. dinonz308
    dinonz308 Formula Junior
    Nov 26, 2017
    869
    Dean
    My M3 did this about a week ago at one station. Doesn't always do it, but I have had it a few times in the M3.
