Gas Smell: Can’t locate | FerrariChat
Discussion in 'Mondial' started by TheEricWilkins, Dec 13, 2023.
  1. TheEricWilkins
    Dec 12, 2023
    1
    Texas
    Eric Wilkins
    Hey folks, I recently bought a super clean 88 Mondial 3.2. Everything looks and runs beautifully but there is a gas smell that is undeniable. My garage reeks of gas. I have taken it to an import mechanic. He replaced a few lines that seemed a little crunchy and it seemed better but when I drove home I was smelling it all the way home and then it just got stronger as the night has gone on while sitting in the garage.
    There is NO visible sign anywhere of gas at all. We had it on a lift and everything and there is nothing. It certainly smells the strongest (by a long shot) by the air box on the passenger side of the engine compartment. Gas cap is on tight. Does anyone have ANY ideas?
  2. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,665
    Argent/Brasil
    Guido
    Fuel tank(s) can have a hole on the upper side. Can only be seen when removing them. Do you have the smell always ? Try to empty tanks to a lower level and see if smell stops. Do this in steps, so you know more or less where a hole can be at what level.
    ronfrohock likes this.
  3. fatbillybob
    Aug 10, 2002
    28,989
    socal
    What about failed EVAP system? 550's tanks known to leak gas smell from failed valve components screwed into the top of the tank. I never had issues with any other ferrari including my mondial cab or similar series/aged 308 but all 550's have the problem. So you may want to look at the EVAP routing.
  4. ronfrohock
    ronfrohock F1 Rookie
    4,154
    MA
    Ron Frohock
    Eric,
    Welcome and great to see you here. Some hoses? Maybe thur tech didn’t find the leaking hose.
    Guido,
    Great advice.
  5. ronfrohock
    4,154
    MA
    Ron Frohock
  6. ronfrohock
    4,154
    MA
    Ron Frohock
  7. Subito Grigio
    Subito Grigio Formula Junior
    Jun 2, 2009
    404
    Please don’t drive it and put it outside. My gut says there are more than sixty connections containing fuel…?
  8. aleib
    aleib Karting
    Oct 12, 2022
    141
    Alejandro Leib
  9. ronfrohock
    4,154
    MA
    Ron Frohock
    First question. Did you fill it up?
    I can tell you that it’s best not to fill it completely and or top it off.
    Second, it’s an older car with hoses that fail from the inside out. Not visible. Replacing the fuel hoses is really a must.
    Not a big deal. Almost anyone can do it. No need to use Ferrari replacements in most cases. Cheep insurance…….
  10. ronfrohock
    4,154
    MA
    Ron Frohock
    I should add that these cars are fairly robust. They just require some basic maintenance due to age, that any car would need. Don’t panic.
  11. Steve Magnusson
    26,785
    Why is the OP banned? I was going to add that one cause of this symptom that has been reported more than once here is someone mounting something in the interior of the car behind the seats and not realizing that the screws that they installed it with have pierced the gas tank in the engine bay ;).
  12. ronfrohock
    4,154
    MA
    Ron Frohock
    He is banned? Strange ?
  13. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,550
    San Carlos, CA
    Mitchell Le
    The last smelly 3.2 Mondial that came through my garage, these were leaking: number 4 and number 63. Ignore the red circles, I just borrowed the picture above.
