Gas smell | FerrariChat
Gas smell
Discussion in '206/246' started by Monch, Jan 11, 2023.
  1. Monch
    Monch Karting
    Aug 29, 2012
    90
    After a long search, Recently bought a Dino. I’m thrilled with how it looks and drives, but have noticed a strong gasoline smell inside the car. This is specially obvious when the car is off. I suspect moving air when driving dissipates the smell. There are no leaks anywhere that I can see.
    Any other Dino owners notice this?
  2. racerboy9
    racerboy9 F1 Rookie
    2,642
    Normally shouldn't smell gas. Check all fuel lines for wetness. Check the fuel inlet banjos on the carburetors as the fiber gaskets sometimes begin to leak with age. I have switched to copper for this reason. Check the fuel filter/fuel pump area as well. There is also the balance pipe that connects the two fuel tanks. I would stay on this till you find the source of the smell. There is a beautiful Lamborghini Miura that burned up in England from fuel leaks.
    morcal and Steve Magnusson like this.
  3. Steve Magnusson
    26,742
    If it's a(n unmodified) euro version 246, it will be a little gas smelly in some conditions because it won't have a fuel fuel evaporation control systems, and the carbs/airbox are just vented to atmosphere. Even if it's a US version (or a modified euro) with a fuel evaporation control system, it still has the carb/airbox vented to atmosphere. However, one of the downsides to the fuel lines with the cloth covering reinforcement on the outside is that the rubber tube inside can have cracks and be weeping/leaking fuel yet the cloth covering still looks dry on the outside. Have your cloth-covered fuel lines been replaced in the last 10 years or so?
    Martyt likes this.
  4. Monch
    Monch Karting
    Aug 29, 2012
    90
    Thanks for the input.
    It’s a Euro car. I’ll have the check on the fuel lines
  5. ENZOSON
    ENZOSON Formula Junior
    660
    Erie, Colorado
    PIETRO
    One more area to check is the top of the passenger side fuel tank. That is where the fuel level sender unit is (round bolt pattern). Known to leak - most noticeable if you just filled the tank and when fuel sloshes around..
    Pietro
    01296
  6. mar3kl
    mar3kl Formula Junior
    Nov 17, 2011
    470
    Silicon Valley
    Mark
    And check the fuel tanks for leaks. Doesn’t need to drop on the floor, could just be weeping through a pinhole enough to smell and then evaporate. And definitely check the fuel filter - there’s a washer that can leak.
  7. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    The most common problem is the smaller return fuel hose from the carb manifold to the fuel tank. It normally leaks on the hose connection above the fuel tank.
    Tony
    (PS it will only leak when the fuel pump is on but leaves a petrol residue that will smell for days after)
  8. daytonaman
    daytonaman Formula Junior
    May 1, 2007
    986
    Australia
    howard pigdon
    That return hose is above the flex filler hose to the tank. On my 330GT I found a leak at the fuel filler hose when the pumps are on. Not visible but you only need a few cc. My hose clamps were tight as, but I guess the hose shrinks and leaves a tiny gap,. Its a pain but only fix is to remove that hose and seal.
    TonyL likes this.
  9. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Sergio Tavares likes this.
  10. Monch
    Monch Karting
    Aug 29, 2012
    90
    I really appreciate everyone’s input. I’ll have my hands full investigating this weekend
  11. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    While the car will smell of exhaust the sharp smell of fuel should never be ignored. Be sure to check all hoses and connections particularly any cloth braided hoses which may have the rubber tubes inside perished but the outer sheathing looks ok. In addition the tanks can have pin holes again below the outer coating that can leak. You'll want to spend a good amount of time looking for the leak and there are some excellent suggestions already in this thread. When checking be sure to disconnect the battery and have a fire extinguisher handy.
  12. Sergio Tavares
    Sergio Tavares Formula 3
    Nov 15, 2018
    1,298
    Sergio Tavares
    Perhaps no problem if you are only a modern car person as carburetted always have this smell
    Always .
    But to much is beyond reason.
    You said "no leaks" and if true then perhaps carburettors run rich. Please pull the dipstick and smell the oil for excessive gas smells. Rich is ok for many running situation but can dilutte engine oil, please take care.
    The fuel filter is sealed by the Square Ring not the O-ring, this should be change at filter change and secured as gasket not O-ring.
    btw, this is not a twist off filter like oil filter (yes it looks like it!) but use the 19mm socket on top through bolt at centered to release filter housing.
    btw there is only 1.1m of 6mm fuel hose, and 0.5m of 5mm return hose and 6/8 clamps. Why not spend 30 minutes every year and change this so importnt items? Where not seen perhaps use 2 clamps at each hose end
    Serious, this is not a big job - the trick is to clamp at tank and start replace at carburettor so last hose point is fuel tank
  13. Sergio Tavares
    Nov 15, 2018
    1,298
    Sergio Tavares
    Hast the smell intruded your other cars interior also in garage ?
    This is when you know you own a Dino, any car in garage smells like petrol!
  14. mccand
    mccand Karting
    122
    San Jose
    Greg McCandless
    This thread (and a chat with Tony) was helpful in resolving my issue (which I made a tiafo! Garage video about as well.
    Thanks as always for the resources here!
    TonyL likes this.
  15. dinogts
    dinogts Formula 3
    So, Monch (the original poster), what was the source of the gasoline smell in your Dino, and how did you fix it?
  16. Monch
    Monch Karting
    Aug 29, 2012
    90
    Sombody had put a screw into the gas tank to hold a bracket. They tried epoxy to fix it. Fuel was leaking out. Had to remove the tank and fix it permanently.
  17. dinogts
    dinogts Formula 3
    Wow. I had a friend who bought a car that prior to his buying it had been in for routine dealer service and got rear-ended by an employee of the dealer.
    The dealer sold the car to him as a CPO'd car, and didn't disclose the accident, and it wasn't obvious.
    A few months later, he noticed a very strong gasoline smell in car. At that point he had moved to another city and had it serviced at another dealer. That dealer's service writers were concerned about it and put it on a hoist. They discovered that the gas tank had been reattached to the car by the prior dealer's OWN REPAIR SHOP using sheetmetal screws through the trunk floor and then they used bondo to try to seal it.
    That could have been a terrible disaster, just like it could have been with your Dino.
