gas springs front and engine hood TR 87 | FerrariChat
Discussion in 'Boxers/TR/M' started by turbo-joe, Jan 17, 2013.
  1. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,544
    romano schwabel
    my 2 gas springs for the engine hood and also for the front hood are not good anymore and after sometimes the hoods came down slowly on my head I like to replace them. but on those I can not read anymore anything right.
    and I don´t want to buy the original ones for a lot of money
    on the rear I read only on one side:
    elektrolift and the numbers 251003 032 ??????E 02
    the other side:
    lift-o-mat 251003 032 ????14/09 E 02
    on the front springs I can not read anything
    my question now: how strong are the front and also the rear? does anybody knows?
  2. Steve Magnusson
    26,830
    This thread has some force data for the rear gas springs for both new and old condition:
    http://www.ferrarichat.com/forum/showthread.php?t=238053&highlight=SG337001
    F PN = 61498100 (the one with the electrical spade connectors used on both sides of a US version TR)
    Sachs Stabilus Lift-O-Mat SG337001
    F PN = 61498000 (the one without the electrical spade connectors used on one side of cars without CHMSL)
    Sachs Stabilus Lift-O-Mat SG337002
    For the Front, do a search on the "SG437003" Sachs PN for the later (SN 76001 and after) cars for prior threads with some force data and discussion of alternatives:
    F PN = 61496700 (front SN 76000 and before)
    Sachs Stabilus Lift-O-Mat = ? (can't recall anyone posting this)
    F PN = 61571600 (front SN 76001 and after)
    Sachs Stabilus Lift-O-Mat SG437003
  3. turbo-joe
    Apr 6, 2008
    9,544
    romano schwabel
    thanks steve.
    so I think that the numbers 032 means the 320 N ?
  4. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    #4 302Tim, Jan 17, 2013
    Yes the "032" you are seeing = 320 Newtons or ~72 lbs. of pressure. On my 1988 TR I have both the original Elekro-Lift struts and they are stamped "0320N". Perhaps some of your ink stamp has worn off. I had mine re-serviced by LS Technologies in Canada because I wanted to keep my originals.
    For the front my originals had already been replaced so when I needed a new set I used Sachs PN 402012, which were a higher pressure than OEM and just slightly longer. They fit fine and have held up with no noticeable loss of pressure for 1.5 years (so far). I have one spare at home--I'll check when I get home from work to see if it is stamped with the operating pressure
  5. ajfriedman
    ajfriedman Rookie
    Oct 2, 2012
    1
    Try NAPA TurboLift: #819-5389 (front), and #819-5589 (rear). These worked fine on my '87.
    Cheers.
  6. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    The Stabilus SG402012 are marked as "498N" or ~112 lbs. of pressure
