Gas stabilizer for 599 while in winter storage? | FerrariChat
Discussion in '612/599' started by pwjj2000, Dec 10, 2023.
  1. pwjj2000
    pwjj2000 Rookie
    37
    Paul
    My 2010 599 HGTE is going to have to go into storage for the winter here in NY in the next week or so.
    Garage where it is kept is very well sealed but is NOT heated. I expect it to be about 4 months in the garage. Gas tank will be left full. I will go and start it up weekly, and if we have a mild winter I will drive it occasionally if and as often as the roads and garage access are completely clear of snow and salt. Fingers crossed for that.
    Anyone have knowledge or experience using gas stabilizer with a 599? Is gas stabilizer even a good idea with a V12? Worth doing it in my case where it will be started up weekly? Any downside to using it?
    Thank you!
  2. Skidkid
    Skidkid F1 Veteran
    9,493
    Campbell, CA
    John Zornes
    My opinion/understanding, keeping in mind that I am not an expert: Starting weekly isn't always a great idea. Unless you get the engine fully warmed up, it puts contamination into the oil. The garage isn't heated so if it is very cold, starting has higher wear until it warms up enough for the oil to perform better.
    I will let someone who knows comment on the gas stabilizer. Personally, I have never used it. Sure, the gas degrades some over the winter but I haven't found the need.
    gsholz likes this.
  3. pwjj2000
    pwjj2000 Rookie
    37
    Paul
    Thanks, I did have some second thoughts on the value of starting it up periodically. When starting it I would definitely let it fully warm up, but never realized or considered a potentially increased wear factor till it gets the oil warmed up. Another consideration........
  4. George Vosburgh
    George Vosburgh F1 Rookie
    I start my car weekly while in storage. I let it warm up and then drive it through the garage slowly just to keep the tires round. The garage sits at about 50 degrees in the winter so I stopped using the stabilizer. I try to only put it away for six weeks starting on January 1. When it comes out it goes for an oil change and anything else that's due. My feeling is that running it is always better than letting it sit, but I could be wrong.
    Chindit and Skidkid like this.
  5. pwjj2000
    pwjj2000 Rookie
    37
    Paul
    Thank you George. I can only roll my car a foot if there is snow outside the door so will use Race Ramp rounded tire pads. My garage is a stand alone and unattached so I imagine it will drop to below 50 in concert with the outside temps. I'd love it if we had a mild winter. And I so hope it will be only stored 6 weeks! Sounds like you are in the camp of doing all service after the winter storage as opposed to before it gets put away? I've heard conflicting opinions and was planning on having mine done now so it sits with fresh fluids and not worn/used ones while in storage. So many nuances to learn..............
    George Vosburgh likes this.
  6. Nospinzone
    Nospinzone F1 Veteran
    Jul 1, 2013
    7,744
    Weston, MA
    Paul
    Yes, use Stabil. Do not start it up weekly unless you are going to drive it for a half hour or so. If you don't drive it, don't worry about the tires if you are using a quality tire.
    DOWORKFCAR likes this.
  7. pwjj2000
    pwjj2000 Rookie
    37
    Paul
    Thanks for the feedback. Tires are Michelin Pilot 4S.
    Skidkid likes this.
  8. Skidkid
    Skidkid F1 Veteran
    9,493
    Campbell, CA
    John Zornes
    You are one of the experts, and a rockstar for driving your car a lot. I drive my car but I am not an expert. Thank you.
  9. Nospinzone
    Jul 1, 2013
    7,744
    Weston, MA
    Paul
    You will have no problem with them. I have been using them since they first came out in 2017.
  10. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,682
    Central NJ
    Dominick
    #10 flash32, Dec 10, 2023
    You can use a fuel stabilizer - but 4 months isn't a long time at all - but if you insist :) you can throw a can of Sea foam in gas tank and drive car for 15 miles before putting away
    Just inflate tires 10 pounds more than normal ( cold)
    Put some baking soda in a dish or two and place on mats
    Put a battery tender on it
    Leave it be until spring - starting without getting oil in transmission up to over 180's 200's will only cause more issues ( condensation)
    One thing I will re-enforce is to make sure your last drive was a nice spirited 15-30 mile drive get all fluids as hot as possible then a few miles of cool down and then store
    Also 4s are very soft . even with inflating over .. you may get a few miles of flat spots vibration when you take it out in spring until then go back to shape
  11. pwjj2000
    pwjj2000 Rookie
    37
    Paul
    Thanks! Appreciate the advice.
    flash32 likes this.
  12. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,682
    Central NJ
    Dominick
    I added a little more to post - wanted to make sure you saw it
  13. pwjj2000
    pwjj2000 Rookie
    37
    Paul
    Got it, thank you.
  14. cgt000
    cgt000 Formula Junior
    777
    Northeast
    I was told to store my cars with as little fuel in the tank as possible.
  15. George Vosburgh
    My understanding of this is that with a fuel tank that will not corrode it's not necessary to keep it completely filled. I fill mine up because I'm starting the car every week.
  16. gsholz
    gsholz Formula Junior
    343
    Oregon
    Jerry
    #16 gsholz, Dec 20, 2023
    In a high humidity environment, such as the PNW, it is good practice to fill the car with ethanol-free gas if you can get it. Prevents water from collecting in the tank as temperatures fluctuate.
    Don't forget rodents looking for a cozy place if you are not driving your car for a while. They can do an amazing amount of damage. I have had good success with several bait stations spread throughout the garage. I always keep my cars on battery maintainers unless they are driven at least weekly.
    Electric cars add other wrinkles when stored for several months. Despite Tesla recommending to keep the battery (Model 3 LFP) at 100%, I set ours to 50% based on the LFP aging charts I have seen. Every week or so, the car will automatically add a couple of KWh to keep the battery at 50%.
    Skidkid likes this.
  17. Skidkid
    Skidkid F1 Veteran
    9,493
    Campbell, CA
    John Zornes
    I have had rodent damage to a car wiring harness. It cost me about $2K and the insurance a lot more than that. That wasn't my Ferrari but same idea. Since the remodel, my garage is tight so no rodents. :)
  18. GasAdams
    GasAdams Rookie
    48
    Gas Adams
    Generally old cars (pre-90's) you should fill to the top. More modern cars put a bit of stabilzer in, leave 1/4 tank for winter, then fill it up first thing in the spring. That's always worked for me.
  19. Skidkid
    Skidkid F1 Veteran
    9,493
    Campbell, CA
    John Zornes
    Care to tell us why you think this?
  20. GasAdams
    GasAdams Rookie
    48
    Gas Adams
    I had a Rolls awhile back. It was from the 60's and I was told to fill it when stored. Some really old cars had steel components in the tank (sensors or the tank itself) that would corrode when exposed to air. The way to prevent this is to fill the tank. Ferrari may have never used steel or corrodable (sp?) components. But, I did this with my older 308, though, and never had a problem. Newer cars don't have corrodable components, so you can keep a small amount of gas in the tank and just fill it up in the spring with fresh gas.
    599_GTO and George Vosburgh like this.
