Gas | FerrariChat
Gas
Discussion in '206/246' started by skierlawyer, Dec 17, 2021.
  1. skierlawyer
    skierlawyer Formula Junior
    Sep 12, 2010
    385
    Golden, CO
    Brian
  2. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    I wish we could get fuel at £0.84p per litre
  3. isuk
    isuk F1 Rookie
    Nov 11, 2005
    3,330
    Iain
    You'd need to fire up the DeLorean and go back to around 2005 to achieve that Tony.
  4. HMB-Dino
    HMB-Dino Formula 3
    2,280
    Pebble Beach, CA
    RonG
    That $4.199/gal is cheap! Around here, it's hovering between $5.19-$5.39/gal for name brand premium gas, self serve!
    V12addict likes this.
  5. swift53
    swift53 F1 Veteran
    8,279
    E.S.
    Alberto
    Brian, no ethanol in Colorado?
    Regards, Alberto
  6. V12addict
    V12addict Formula Junior
    Jan 2, 2004
    293
    I got gas for $ 5.89 on the way to Big Sur last Summer and naturally there are not many stations in that area.:eek:
  7. Ianjoub
    Ianjoub Formula Junior
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    Just right of the price you can see 1/2 of what it says: All fuels contain up to 15% (or maybe 10%) ethanol.
    swift53 likes this.
  8. swift53
    swift53 F1 Veteran
    8,279
    E.S.
    Alberto
    Agreed, it contains ethanol, I wrongly assumed Colorado did not have Ethanol.
    In that case, I prefer to spend $10 x gallon for 114 octane, Sunoco Leaded, considering the huge ( :) ) amount of fuel we use,
    and the lessening of repairs / damages due to ethanol. Not to mention the HUGE difference in fuel quality and performance.
    Oh, and the aroma is much better out the exhaust
    Regards, Alberto
  9. Ianjoub
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    Better not use the leaded fuel if you retained catalytic converters.
  10. swift53
    swift53 F1 Veteran
    8,279
    E.S.
    Alberto
    This is the Dino section, no cats on Dino...and plenty of ethanol damageable carbs.
    Regards, Alberto
    Ianjoub likes this.
  11. Ianjoub
    Dec 22, 2019
    906
    Homosassa, FL USA
    Ian Joubert
    I am guilty of not paying attention to that. I use the 'new post' feature. I didn't put 2 and 2 together with the pic of the Dino at the pump. If the valve seats were never done on older cars, running unleaded fuel destroys the valve seats fairly quickly.
    swift53 likes this.
  12. TonyL
    TonyL F1 Rookie
    Sep 27, 2007
    4,202
    Norfolk - UK
    Tony
    Not to mention fuel lines, this is 3 month old SAE R9 fuel hose which is supposed to be E15+ rated. Later identified as counterfeit goods.
    of2worlds likes this.
  13. tx246
    tx246 F1 Veteran
    6,660
    Texas
    Shawn
    Not relevant to the “Fuel” aspect of this conversation, but VERY RELEVANT....
    I bought a Dino in Denver. I still own it. Years ago, before threads like this helped all.
    I am obviously dumb. That Dino was set to run at an altitude we don’t have in Houston, Tx.
    ANY Dino, or Carb’ed Ferrari, that is being moved from substantial elevations will need to be adjusted.
    I am sure this probably applies for any carbed vehicle, but probably isn’t a top of mine thing.....
    Shawn
    UroTrash, swift53 and of2worlds like this.
