Gasket removal, Help | FerrariChat
Discussion in 'Technical Q&A' started by Harta320, Mar 22, 2004.
  1. Harta320
    Harta320 Karting
    Nov 6, 2003
    169
    Sarasota, FL
    Bill Smith
    I have started my 30000 mile service (83 308) and the old gaskets on the cam cover and the head do not seem to want to go. What is the best way to remove the gaskets without damaging anything? I am just about to pull the cams, put on new cam seal gaskets, and start getting this thing back together. Oh yea, what is the torque values for the cam cap nuts? Thanks in advance. Well, off to the garage to come up with another question or 2!
    Bill
  2. ShanB
    ShanB Formula Junior
    Jul 9, 2003
    547
    Tejas/Europe/Desert
    shanb
    The last shop that removed the valve covers on my car went crazy with sealer which took a lot of work to remove. I used Permatex Gasket Remover and a fine "nylon wool" type polishing pad. Here are a few pics of the product and results. As far as the tightening torqe for the caps - it's very low, around 8-10 Nm, but check your WSM to be sure.
    all the best,
    Shan
  3. Harta320
    Harta320 Karting
    Nov 6, 2003
    169
    Sarasota, FL
    Bill Smith
    Thanks Shan for the info. That stuff looks like it worked perfect.
  4. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    TIGHTENING TORQUE IS 9 FT/LBS
  5. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    the tightening torque for cam bearing caps = 6:1/2 ft. lbs or = 78 in lbs .
  6. ShanB
    Jul 9, 2003
    547
    Tejas/Europe/Desert
    shanb
    Which is around... 8-10 Nm right?
  7. yelcab
    yelcab F1 World Champ
    Nov 29, 2001
    13,689
    San Carlos, CA
    Mitchell Le
    No, 9 ft-lbs is more like 12-13 Nm
  8. ShanB
    Jul 9, 2003
    547
    Tejas/Europe/Desert
    shanb
    Thanks - I learn something new every day.
  9. Harta320
    Harta320 Karting
    Nov 6, 2003
    169
    Sarasota, FL
    Bill Smith
    Hey guys, thanks for the help. The gasket remover did the trick Shan. Still had to use way to much elbow grease though.
  10. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    I'm sorry, ria is right. The WSM says .9 KGM=6.5097124 ft/lbs
  11. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,761
    Argent/Brasil
    Guido
    Is there someone who makes the cam cover gaskets himselve. If so, what material is he using, where to get it.
    Thanks, Guido
  12. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    Guido,
    I just made them using Aramid gasket material from McMaster Carr. Premium Aramid with buna binder.
    http://www.mcmaster.com/
    I have not reinstalled the engine yet so I have no idea how it works.
    I am pretty sure that any leaks would be at the oil seals and not from the gasket itself.
    Cheap set of punches from Harbor Freight, scissors and exacto knife all it took.
  13. theunissenguido
    Jan 21, 2004
    2,761
    Argent/Brasil
    Guido
    Problem is, I live in Belguim. So McMaster Carr....have no clu. Any website information to order it by mail ? Let me know if it works without leaks,ok. Thanks , Guido
