360 - Gasket seal? Oil rear plug cover replacement? | FerrariChat
360 Gasket seal? Oil rear plug cover replacement?
Discussion in '360/430' started by BrettC, Jul 31, 2022.
  1. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Replacing the aluminum cover with the Hill model. Owned car for 8 years and now it has finally gave up the threads on the plug and cover. Taking off the old one.....no sealer I can see? Can it be? Gotta use something. It is a plate attached to a plate. Help buddies????
  2. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Are you saying there’s no gasket or are you asking what sealer to use? If you have a gasket and want to seal it so you won’t ever have a problem in the future, use Hondabond.
    LorenzoR likes this.
  3. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    Well, in taking it apart I noticed no gasket or sealer compound whatsoever...seems like the plates just bolted together....
  4. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Wow. How did it not leak?
    I’d get a gasket for it and use Hondabond. It all has to be squeaky clean before you put it back together.
  5. BrettC
    BrettC Formula 3
    Aug 13, 2012
    2,115
    Calif
    Brett
    You could've ate off it after my cleaning, RTV black was the recommended sealant. Worked fine. Thanks again! Where to buy Hondabond anyway? Amazon?
  6. flash32
    flash32 F1 Veteran
    Aug 22, 2008
    6,914
    Central NJ
    Dominick
    I would have recommended loctite 518 or prematex ultra black
  7. Extreme1
    Extreme1 Formula 3
    Jun 27, 2017
    1,423
    Santa Clarita, CA
    Yep, Amazon.
  8. Ricambi America
    Sponsor Owner
    There is no paper gasket intended in that location. RTV only.
