Gasket set for 355 (2.7 motronic) | FerrariChat
Discussion in 'Technical Q&A' started by BigHead, Jan 28, 2004.
  1. BigHead
    BigHead Formula Junior
    Oct 31, 2003
    995
    Outside of Boston
    Dennis
    I need the complete gasket set for a 355 motor (1995, 2.7 Motronic). It's part # 165725. The best deal I've found, after beating up a few of the usual suspects, is just over a GRAND. A thousand bucks for a gasket set!?!? Jeez, am I nuts, or is this just a crazy price for a set of GASKETS?!?
    Your opinion would be appreciated!
    vty,
    --Dennis
  2. Mitch Alsup
    Mitch Alsup F1 Veteran
    Nov 4, 2003
    9,763
    Must only be a top end rebuild gasket set, the whole engine set is closer to 2 grand!.
    A) whether you are nuts or not is not answereable at this point
    B) this is crazy, but what can one do.
  3. Gianluca
    Gianluca Formula Junior
    May 6, 2003
    349
    Centreville, Virgini
    Gianluca Chegai
    I am making my own for a 308. Took most of the engine apart with the exception of the heads.
    Places like McMaster Carr or MSC have a variety of gasketing material in different thicknesses.
    An exacto knife and a set of punches plus a little time should do it.
    The way I mark my gasket is to spread a thin coat of grease or, if the gasketing material is impervious to grease, anti-seize compound on the part (without studs) and then "press" it on the gasket sheet. All the details will be clearly visible. Punch all the holes first then do the exacto cutting.
    Harbor Freight has several sets of punches from just a couple of bucks to about $ 35 for a set up to 2" (maybe more).
    Please, understand that I have no knowledge of a 355 so the above may not apply. Then again, is a piece of the appropriate material cut to the right shape. Should be fairly easy.
    Hope this help.
  4. Diablo
    Diablo Formula Junior
    The gasket sets are very pricy, due to the fact that these gaskets are not very common.
    I have had people look for F40 cyl. head gaskets. No dealer in the US had them. I finally had luck and Wide World got them.
  5. HGParts
    HGParts Formula Junior
    Mar 15, 2003
    456
    Germany
    Heiko from HGParts
  6. ricrain
    ricrain Karting
    Nov 1, 2003
    213
    Dallas Area
    Ric
    Hey Dennis. Ric here.
    If it's like the 348 set, TR set and 308 set, the gasket set contains:
    1) ALL the gaskets (head gaskets, valve cover, rear main, timing cover, cam ends, intake runners, AND the asbestos exhuast donuts, etc.)
    2) ALL the oil seals (cam seals, timing cover, rear main seal, etc.)
    3) ALL the rubber O-rings (including the cylinder liner O-rings, fuel injector O-rings, etc.)
    4) ALL the valve stem seals
    5) ALL the copper gaskets
    6) ALL the other little tidbits (water pump seals, etc.)
    Basically, everything you need to completely rebuild the entire engine, except pistons rings, valve guides and bearings.
    In that light, it's still costly, but not like purchasing it all separately!
  7. Nick
    Nick Formula Junior
    Sponsor Professional Ferrari Technician
    Oct 31, 2003
    506
    Nick Scianna
    Give me a shout I should be able to get you the lowest price around,
    e mail me at my Italian e mail adress. [email protected].I will ship it directly from Italy to you if you are still looking for a gasket set. Nick Scianna www.nicksforzaferrari.com
    Ferrari chat's oldest Sponsor.
