Gasoline Preference- How Do You Choose? | Page 2 | FerrariChat
Discussion in 'Technical Q&A' started by ZINGARA 250GTL, Mar 19, 2007.
  1. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Who ever is cheapest. :D
  2. wg8221
    wg8221 Karting
    Aug 12, 2006
    53
    Niceville, Fl
    Bill
    The only difference in gasoline is the additive package and I wonder if the additives are always added correctly. Where I live all gasoline comes in single barges from the refinery. It is delivered to a CITGO Terminal and all of it is offloaded into the same tanks. CITGO then puts the additives into the gasoline as part of the process of loading the trucks. This is when it supposedly becomes Shell, BP, Chevron, etc.
    So if you are getting better performance from a particular brand its either because of the additives specified by a brand or perhaps a placebo.
  3. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Exactly!
    Which is why I shop for the cheapest.
  4. f355spider
    f355spider F1 World Champ
    18,056
  5. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    there was a thread on this a while back and if i remember chevron was the winner. seems the additive techtron really helps to clean the fuel injectors.
  6. MREUS
    MREUS Formula Junior
    Jul 24, 2006
    832
    Huntington Beach, CA
    I prefer Chevron because of the Techron...but don't go out of my way for it. I have also used their fuel additive for my 308. The Ferrari Dealer Technician recommended it to keep the fuel injectors clean.
    I heard about this a while back too:
    http://www.chevron.com/products/prodserv/fuels/techrongas/successbig3.shtml
  7. kerrywittig
    kerrywittig Formula 3
    1,668
    Ithaca, New York
    Kerry David Wittig
    My brand choice is based on octane rating. At this time I am using 110 octane gasoline. The brand at the pump is displayed as Chevron....which may or may not be accurate. I believe that the octane rating is the way to judge which fuel you decide to use, as well as finding and/or feeling a performance difference..............Kerry
    P.S. Access to the pump is an important factor though...........speed bumps and steep inclines are a definite consideration............great fuel versus shredded front spoiler.......LOL
  8. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    Used to be only Chevron, but now Texaco too, both with Techron.
  9. Gerry328
    Gerry328 F1 Rookie
    2,629
    Home
    Gerry
    Buying based only on the highest octane may mean you are spending more than you need for gasoline. You only need the octane recommended by the OE. If 93 is recommended, using a higher octane will have no affect on performance.
    However, if you OE calls for regular 87, occasionally using premium will give you a higher additive treat rate. That is very similar to buying Techron gasoline additive and putting in you tank. If you are already using a major brand premium (Chevron, Texaco, BP, Shell, Mobil, Exxon) you do not need to also use a gasoline additive.
  10. dinogt4guy
    dinogt4guy F1 Rookie
    Oct 31, 2004
    3,411
    Hewitt, Tx.
    Kurtis Fordice
    Chevron with Techron, allways.
    Cheers!
    DT
  11. Gatorrari
    Gatorrari F1 World Champ
    16,526
    Georgia
    Jim Pernikoff
    I have been putting mid-grade (89 pump octane) BP/Amoco in my 328 for nearly two years and have noticed no negative effects! (In fact, my 2000 Civic Si likes the mid-grade gas much less than the Ferrari!)
  12. Gerry328
    Gerry328 F1 Rookie
    2,629
    Home
    Gerry
    Midgrade product, as you would expect has an additive treat rate that is between regular and premium. Some years ago Amoco reduced the treat rate of the Regular product to just meet the minimum specs. Midgrade and Premium were higher than the minimums, and at a treat rate needed to achieve the marketing and quality claims.
  13. E60 M5
    E60 M5 Moderator
    Moderator Owner
    Jan 2, 2006
    8,181
    Wash DC area
    Robert
    I am a little anal, I stop at the same Shell station all the time. I know its stupid, but allow me this one little quirk!!!
    Robert
  14. kerrywittig
    1,668
    Ithaca, New York
    Kerry David Wittig
    Trust me...........there is a difference in engine "performance" between Sunoco 93 and Cheveron 110.....
    And I am a cheap f**k, I take the extra roll of toilet paper in hotels for my home.........haven't bought T-paper in years! Let's me be able to afford the 110 fuel, very possible even the ability to own and maintain a TR.........LOL
  15. ZINGARA 250GTL
    ZINGARA 250GTL F1 World Champ
    Jun 21, 2002
    17,499
    PA
    Ken
    Sure. You're a nice boy. If my mother were still alive, (God rest her bi-polar, drive me nuts soul) I'm sure she would allow you your little quirk. And, so do I, since this is my thread. Thanks for the input! Cheers.
  16. ZINGARA 250GTL
    Jun 21, 2002
    17,499
    PA
    Ken
    Let's not get off-track. I wasn't talking about changing recommended octane ratings (although there ain't no way I'm putting 93 octane in an E320). I'm talking about how you make you buying decision after you determine what octane you need.
  17. f355spider
    18,056
    Of course mid grade would be in the middle between regular and premium, since there are only two tanks at the gas station....mid grade is simply a blend of regular and premium at the pump! :)
  18. Gatorrari
    16,526
    Georgia
    Jim Pernikoff
    If that were the case, why isn't mid-grade gas 90 (pump) octane? Regular is 87 and premium is 93; average them out and you get 90. So why is mid-grade 89 octane instead??
  19. ernie
    Nov 19, 2001
    22,628
    The Brickyard
    The Bad Guy
    Because they can control the mixture.
    However it would probably be closer to 90 octane. The gas manufacture MUST meet the advertised octain rating. So, they cheat it a little high just to make sure they aren't under. When you go to fill up next time, have a look at the date in the inspection sticker on the pump. They inspect the pump quite often.
    On a side note, the best time to fill up is early in the morning. The reason is because the gasoline has had a chance to cool. During the day the gas does expand with the heat build up in the ground, especially in the summer. So you don't get as much gas. It probably isn't that much, but if your filling up a RV, or a boat, you may get an extra few ounces of gas doing it after the night has cooled down the ground temperature.
  20. gothspeed
    gothspeed F1 World Champ
    May 26, 2006
    10,244
    U.S.A.
    goth
    :eek: Where do you get 93 octane??? I have only found 91 octane at local gas stations :( .
  21. Gerry328
    Gerry328 F1 Rookie
    2,629
    Home
    Gerry
    Nope, majors have three tanks, one for each grade. Sun was the only oil company that had blend pumps at retail, not very reliable.
  22. JCR
    JCR F1 World Champ
    11,079
    H-Town, Tejas
    Outside of California :)
  23. BigAl
    BigAl F1 Veteran
    Mar 17, 2002
    6,146
    TX
    GSgt Hartman
    I think I used to get 93 at Amoco in Virginia years ago.
  24. ClydeM
    ClydeM F1 World Champ
    12,147
    Wayne, NJ
    Clyde E. McMurdy
    Chevron would be my choice if it were readily available here in NJ, but it isn't.
    That said, I did an impromptu test of various gasolines (3 consecutive fills and regular record keeping) and grades over the years on my 308 and found
    about 1mpg more for hi-test. So I stick with regular (87 octane)
    just under 1mpg more for using Hess as opposed to Exxon, Getty, Citgo, Mobile, generics so I try & use Hess
    Here in NNJ, lots of traffic everywhere so "fresh" gas isn't too much of a problem anywhere.
    I didn't notice any performance increase in any brand of gas.
    Oh, and I toss a bottle of Techron into the tank every so often. Maybe every 3 months or so.
