Gasoline(?) | FerrariChat
Gasoline(?)
Discussion in 'Boxers/TR/M' started by 300GW/RO, Dec 29, 2012.
  1. 300GW/RO
    300GW/RO Formula 3
    Nov 7, 2010
    1,033
    east end LI
    Jack
    This topic has re-surfaced in GullWing Group and I've not noted around these threads...although I know must exisit in F-world/chat...I would appreciate a heads-up for octane, additives etc for '81 512 bb?? and earlier.
    Thanks all very much!! Jack
  2. CarbBoxer
    CarbBoxer Formula Junior
    Oct 7, 2008
    844
    Houston
    PW
    I do not find the stock compression ratio to require anything beyond premium pump gas.
  3. Steve Magnusson
    26,842
    And, with hardened valve seats, unleaded gasoline/E10 gasohol hasn't been reported as problematic for BB/BBi (if not left to separate ;)). What "issue(s)" is(are) the GullWing having with modern fuels?
  4. boxerman
    boxerman F1 World Champ
    19,749
    FL
    Sean
    the motor is much smoother with a 50/50 blens of race gas and superunleaded. I find most cars run better whgen the alcohol content is below 5%. you can run on superuleaded, it just goes much better with a blend, same with my old motorcycle..
  5. ago car nut
    ago car nut F1 Veteran
    5,506
    Madison Ohio
    David A.
    There are some gas stations that are alcohol free. But sometimes hard to find. Google alcohol free gas stations.
    Ago
  6. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Not sure about the USA, but in Canada the premium grade at Esso and Shell is ethanol-free .. easy to find ... which is good.
  7. John B
    John B Formula 3
    May 27, 2003
    1,564
    NJ
    Here in NJ we can't get any gasoline without 10% ethanol. I use Aviation 100LL (100 octane, Low Lead, no ethanol) in my old motorcycles. I don't think that will be practical for a Boxer though.
  8. sparky p-51
    sparky p-51 Formula 3
    Aug 8, 2004
    1,375
    klamath falls, Or.
    steve
    Have been burning non alcohol 92 oct gas in the 87 TR here in Oregon for the past 2 years. Cost 45 cents more but at least the fuel hoses are not degrading. Hope the high oct does not harm the momo. Any thoughts?
  9. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    i can get 110 oct at speedway i dont know if it is a good thing to put in my 86 TR.
  10. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    I'm sure you don't need me to tell you this, but that sucks!!!
    Don't you just hate it when the powers that be decide what's best for the general public and then enforce a "one size fits all" approach.
  11. Zxgarage
    Zxgarage Formula Junior
    638
    MD/ DC area
    Zack
    Old cars are doomed with "Flex Fuel"... Ethanol.
    What we need is an additive that really works.
    Does Stabil for ethanol works ? I got some and I can't tell yet.
    I replace a fuel regulator on a Hot Rod, after one year that the car was parked, on three months... leaking again. Like if the rubber inside was decomposing.
  12. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    In the early Testarossa days (mid 80's) Petrol was 98 or 101 octane. I don't believe that there was any fuel hose problems at the time.
    HTH
    P
  13. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    i order a test kit that way i will know witch gas station will have less ethanol in it next time i get fuel for the TR at $30.00 kit will last a long time. some gas stations in ohio have less ethanol than others.
  14. 300GW/RO
    300GW/RO Formula 3
    Nov 7, 2010
    1,033
    east end LI
    Jack
    aside from rubber hoses & bits degrading..the real issue is with the 300sl mechanical fuel injection pump. It will continue to 'inject' fuel after engine shut-down via ignitiom switch (key), w/c essentially 'washes' the crank/pistons/cylinder walls etc of residual oil/lubricant. Therefore, with modern fuels lacking much, if any, lubricating properties (read alcohol)...the 'fuels' hasten engine wear by 'cleaning' these components. I 'turn-off' my engine via clutch-stall while in 4th.....hard to tell which is more harmful!!
